posted this
01 June 2015
Sorry for the delay.
I want only "register" appaer when you aren't logged in or if you don't have an account yet. Else I don't want to see the register link/button.
Unfortunately Themler does not have such built-in functionality.
To add additional link to the top menu you will need to edit theme files manually.
open public_html\themes[theme_name]\includes\topmenu_1.tpl file
there is {if $logged}loop in this file. If you want to add a link which should appear only if you're not logged in you should add it outside this loop after the {else} tag.
in the same file you can remove "your name":
<li class=" bd-menuitem-1">
<a href="{$link->getPageLink('my-account', true)}" title="{l s='View my customer account'}" account" rel="nofollow"><span>{$cookie->customer_firstname} {$cookie->customer_lastname}</span></a>
</li>
Please note that saving theme in Themler may erase all custom changes. So I suggest that you either make changes to the final theme or do not make any changes to the Top menu control in the future.
- open <tt>public_html\themes\[theme_name]\includes\topmenu_1.tpl</tt> file
- there is `{if $logged}`loop in this file. If you want to add a link which should appear only if you're not logged in you should add it outside this loop after the `{else}` tag.
- in the same file you can remove "your name":
`<li class=" bd-menuitem-1">
</li>`
