I’ve run into similar mobile menu issues in Themler before, and in most cases it ended up being related to either CSS conflicts or how the responsive menu container is styled rather than WordPress itself. Sometimes the menu does render, but it gets hidden behind other elements or doesn’t properly trigger the toggle event on mobile view.
Another thing worth checking is whether any custom scripts or plugins are interfering with the responsive behavior, since Themler themes can be quite sensitive to external JavaScript changes. Clearing cache and re-saving the theme settings has also helped in some cases I’ve seen discussed in similar threads.
Also, when working with structured content or testing text across different platforms, tools like textoinvisibles solución online can sometimes be useful for formatting or handling special characters in a controlled way.
Hopefully this helps narrow it down.
Also, when working with structured content or testing text across different platforms, tools like [textoinvisibles solución online][1] can sometimes be useful for formatting or handling special characters in a controlled way.
[1]: https://textoinvisibles.com/
