1 Updates in desktop Themler
hansu
hansu posted this 24 April 2017
Hi, I seem to get the same "1 Updates" warning each time I open Themler on my desktop (Win10), despite having installed the latest Themler update (20 April 2017) twice now. This is valid both for selecting WP and Joomla templates.
Is this warning an update to the individual CMS you are using, or should it be common to all templates in Themler?
Any ideas?
Hi, I seem to get the same "1 Updates" warning each time I open Themler on my desktop (Win10), despite having installed the latest Themler update (20 April 2017) twice now. This is valid both for selecting WP and Joomla templates. Is this warning an update to the individual CMS you are using, or should it be common to all templates in Themler? Any ideas?
Support Team posted this 25 April 2017
Each theme is updated separately, so you can decide when to update a specific theme. You can check the version of the currently selected theme in your profile in the top right corner.
Hello, Each theme is updated separately, so you can decide when to update a specific theme. You can check the version of the currently selected theme in your profile in the top right corner. Sincerely, Nettie, BillionDigital Team
hansu
hansu posted this 25 April 2017
Thank you for quick response Nettie.
I was not thinking of "each theme" but "each CMS" as I am using the Desktop version of Themler, and this pops up when I select Joomla or Wordpress before accessing the actual theme. Hope this is a bit clearer?
Best regards,
Hans
Thank you for quick response Nettie. I was not thinking of "each theme" but "each CMS" as I am using the Desktop version of Themler, and this pops up when I select Joomla or Wordpress before accessing the actual theme. Hope this is a bit clearer? Best regards, Hans
Hello Hans,
As there are different themes in each CMS (though they can look similar if they are default themes), then yes, they should be updated separately. If there is an already modified theme saved under a different name - there should be an update notification for it, and after you update it, save it. When you run Themler and open the same theme next time (select it in the theme management screen), the theme should already have a new version and no new update notification should be shown (until there is some other newer version available).
Hello Hans, As there are different themes in each CMS (though they can look similar if they are default themes), then yes, they should be updated separately. If there is an already modified theme saved under a different name - there should be an update notification for it, and after you update it, save it. When you run Themler and open the same theme next time (select it in the theme management screen), the theme should already have a new version and no new update notification should be shown (until there is some other newer version available). Sincerely, Nettie, BillionDigital Team
hansu
Will look further in to this, and provide feedback when I have had the time to do so.
Best regards,
Hans
Nettie, Will look further in to this, and provide feedback when I have had the time to do so. Best regards, Hans
Hello Hans,
Ok, we will be waiting for your results.
Hello Hans, Ok, we will be waiting for your results. Sincerely, Nettie, BillionDigital Team
hansu
hansu posted this 26 April 2017
Your explanation solved it, as I overlooked the fact that this warning would be valid for each theme, regardless of CMS.
Thank you.
Nettie, Your explanation solved it, as I overlooked the fact that this warning would be valid for each theme, regardless of CMS. Thank you.
Support Team posted this 27 April 2017
