Themes Themler Joomla
service@brandewie.de
service@brandewie.de posted this 27 April 2017
Hello.
What files do I need to copy to the thetemplate directory so I can edit the themes again with Themler? All theme / themes are deleted after reinstallation. Help Important. There are Joomla Themes. Thank you
Hello. What files do I need to copy to the thetemplate directory so I can edit the themes again with Themler? All theme / themes are deleted after reinstallation. Help Important. There are Joomla Themes. Thank you
Support Team posted this 27 April 2017
Please provide more details. You have Themler themes exported without editor or what? Actuallhy you can not simply copy some files and edit the theme in Themler.
Hi, Please provide more details. You have Themler themes exported without editor or what? Actuallhy you can not simply copy some files and edit the theme in Themler. Sincerely, Hella
Hello.
Yes, I have exported all Themes from Themler without Themler. What files do I need to copy to the exported folder so I can edit the theme in Themler again?
Hello. Yes, I have exported all Themes from Themler without Themler. What files do I need to copy to the exported folder so I can edit the theme in Themler again?
Hello.
Can you tell me how I can work now?
Hello. Can you tell me how I can work now?
There is no possibility to edit the themes that were exported without editor included.
Hi, There is no possibility to edit the themes that were exported without editor included. Sincerely, Hella
But it can not be that all my templates are gone. There must be a possibility to import again?
I have not synonymous selected everything to be deleted during the installation. Still, all the themes are gone.
This is a program error ....
I have not synonymous selected everything to be deleted during the installation. Still, all the themes are gone. This is a program error ....
If the theme exported with Themler it contains one important file called project.json. This file is individual for all themes and contains all theme settings like included controls with their ID, settings, etc. Without this file and some other files the theme cannot be opened in Themler for editing.
As I understand you lost all your themes with Themler somehow? And you did not make backups?
If so then themes cannot be opened back in Themler. There is no way to restore lost project.json.
Hi, If the theme exported with Themler it contains one important file called `project.json`. This file is individual for all themes and contains all theme settings like included controls with their ID, settings, etc. Without this file and some other files the theme cannot be opened in Themler for editing. As I understand you lost all your themes with Themler somehow? And you did not make backups? If so then themes cannot be opened back in Themler. There is no way to restore lost project.json. Thank you, Olivia
