No CSS styles on the "offline site" page with the latest version of Themler and Joomla 3.7
Pierre665
Pierre665 posted this 27 April 2017
There are no CSS styles on the "offline site" page with the latest version of Themler and Joomla 3.7.
Hi, There are no CSS styles on the "offline site" page with the latest version of Themler and Joomla 3.7. Regards
6 Comments
Support Team posted this 27 April 2017
The front end themes usually do not provide styles for this login form. Joomla provides own styles in the /templates/system/css/offline.css file. Please make sure that this theme exists on your server.
Hi, The front end themes usually do not provide styles for this login form. Joomla provides own styles in the `/templates/system/css/offline.css` file. Please make sure that this theme exists on your server. Thank you, Olivia
silentnickk
silentnickk posted this 28 April 2017
У меня то же самое. Joomla 3.7 не берет почему то стиль из системной папки /templates/system/css/offline.css.
Вернулось все на место только после копирования offline.css непосредственно в папку шаблона.
У меня то же самое. Joomla 3.7 не берет почему то стиль из системной папки /templates/system/css/offline.css. Вернулось все на место только после копирования offline.css непосредственно в папку шаблона.
info2934
info2934 posted this 04 May 2017
This theme exists... How can we fix it?
Solved: copy the file offline.css that is in the directory \templates\system\css to the directory \templates\themler-template\css. This should take care of the situation.
> Hi, > > The front end themes usually do not provide styles for this login form. Joomla provides own styles in the `/templates/system/css/offline.css` file. Please make sure that this theme exists on your server. > > Thank you, > Olivia This theme exists... How can we fix it? Solved: copy the file offline.css that is in the directory \templates\system\css to the directory \templates\themler-template\css. This should take care of the situation.
Support Team posted this 04 May 2017
I've found the same issue on joomla bug tracker:
https://issues.joomla.org/tracker/joomla-cms/15614
Looks like this is joomla bug.
The copying the file into the theme folder/css fixes the issue temporarily.
Hi, I've found the same issue on joomla bug tracker: https://issues.joomla.org/tracker/joomla-cms/15614 Looks like this is joomla bug. The copying the file into the theme folder/css fixes the issue temporarily. Thank you, Olivia
Pierre665
Pierre665 posted this 04 May 2017
Ok, thank you !
Hi, Ok, thank you !
Support Team posted this 05 May 2017
