How to import theme created in Themler from Wordpress / Woocommerce
Inovaweb Tec
Inovaweb Tec posted this 27 April 2017
I've previously exported themes created in Themler to my clients without including Themler for customization, and whenever we need, we import without any problem! This time as we had to uninstall the program, on your recommendation, to try to solve the problem of Joomla and Virtuemart CMS that do not work, when reinstalling and importing the themes is what happened.
To this day I still have not been able to solve this question, so my question is, is there any way I can integrate Themler again into themes created in it through Wordpress? If so, please let me know, because then again I have the themes again with Themler to customize and I would do the export / import again
Thank you for your help, because if you can not re-edit these themes with Themler I will have to redo them again for my clients.
Thank you.
Hello I've previously exported themes created in Themler to my clients without including Themler for customization, and whenever we need, we import without any problem! This time as we had to uninstall the program, on your recommendation, to try to solve the problem of Joomla and Virtuemart CMS that do not work, when reinstalling and importing the themes is what happened. To this day I still have not been able to solve this question, so my question is, is there any way I can integrate Themler again into themes created in it through Wordpress? If so, please let me know, because then again I have the themes again with Themler to customize and I would do the export / import again Thank you for your help, because if you can not re-edit these themes with Themler I will have to redo them again for my clients. Thank you.
Support Team posted this 28 April 2017
Did you create the theme with Themler desktop? If so, they should have been stored in the location like C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\virtuemart. They can be still there (if you haven't remove all CMS content while uninstalling Themler) or if you copied the themes from this folder, then can be imported back in Themler.
If a theme was exported with the box "Include Themler" unchecked on export, unfortunately, such theme cannot be imported back in Themler for editing, though it can be installed in a CMS like any other theme.
Hello, Did you create the theme with Themler desktop? If so, they should have been stored in the location like `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\virtuemart`. They can be still there (if you haven't remove all CMS content while uninstalling Themler) or if you copied the themes from this folder, then can be imported back in Themler. If a theme was exported with the box "Include Themler" unchecked on export, unfortunately, such theme cannot be imported back in Themler for editing, though it can be installed in a CMS like any other theme. Sincerely, Nettie, BillionDigital Team
alexarafatonline
alexarafatonline posted this 21 July 2025
I totally get your frustration—I had a similar issue when I lost access to a tool I relied on. It reminded me of when I used to play hay day unblocked. At first, the original game felt great, but the slow progress and resource limits really held me back. Once I found the unblocked version with unlimited resources, everything became smoother and more enjoyable. Hopefully, just like that fix worked for me, you’ll find a way to reintegrate Themler without having to rebuild everything from scratch.
I totally get your frustration—I had a similar issue when I lost access to a tool I relied on. It reminded me of when I used to play [hay day unblocked][1]. At first, the original game felt great, but the slow progress and resource limits really held me back. Once I found the unblocked version with unlimited resources, everything became smoother and more enjoyable. Hopefully, just like that fix worked for me, you’ll find a way to reintegrate Themler without having to rebuild everything from scratch. [1]: https://haydaymodapk.com/
