Probem php memory
frederic11
frederic11 posted this 29 April 2017
i have a problem, i have just upgrade to Joomla 3.7, and i havent check before is there was an update of Themler.
No, i have a php memory limit error when try to open Themler. But the memory is good on my server and never have this problem before.
Thanks for help.
Hello, i have a problem, i have just upgrade to Joomla 3.7, and i havent check before is there was an update of Themler. No, i have a php memory limit error when try to open Themler. But the memory is good on my server and never have this problem before. Thanks for help.
30 Comments
frederic11
frederic11 posted this 11 May 2017
it seem there is no stable update now ? Because i want to install a fresh template and when i try to open, same problem...
Hello, it seem there is no stable update now ? Because i want to install a fresh template and when i try to open, same problem...
Vitaliy WD
Vitaliy WD posted this 11 May 2017
There is Beta which can be marked as Stable if no new issues will be found.
> Hello, > > it seem there is no stable update now ? Because i want to install a fresh template and when i try to open, same problem... There is Beta which can be marked as Stable if no new issues will be found.
frederic11
You can't download beta version from the Themler.com download page.
Support Team posted this 12 May 2017
Hello Frederic,
This is an update from server and not a new installation file or new theme zip. Just update a new or existing theme where you work at it (for example, in Themler desktop or on your server) by clicking "1" in the right circle - this is the update notification on the top right when you open some Themler theme. As this is a Beta update, make sure to have Beta updates enabled in your profile.
Hello Frederic, This is an update from server and not a new installation file or new theme zip. Just update a new or existing theme where you work at it (for example, in Themler desktop or on your server) by clicking "1" in the right circle - this is the update notification on the top right when you open some Themler theme. As this is a Beta update, make sure to have Beta updates enabled in your profile. Sincerely, Nettie, BillionDigital Team
apsite
apsite posted this 12 May 2017
Hi!
I'm upgraded a beta but it still doesn't work.
Hi! I'm upgraded a beta but it still doesn't work.
apsite,
If you updated theme to the latest beta and something is still not working please create a new private topic and provide more details about the issue including screenshots and access to the CMS admin panel so we can check the issue.
apsite, If you updated theme to the latest beta and something is still not working please create a new private topic and provide more details about the issue including screenshots and access to the CMS admin panel so we can check the issue. Thank you, Olivia
marcin_tomas
marcin_tomas posted this 14 May 2017
marcin_tomas,
The issue does not happen on our end. Possibly there are some third-party plugins or components that are related to the issue - could you please try temporarily disabling them and let us know if this makes any difference?
No plugins is installed on the site. The page is in the projection phase..
> **marcin_tomas**, > > The issue does not happen on our end. Possibly there are some third-party plugins or components that are related to the issue - could you please try temporarily disabling them and let us know if this makes any difference? > No plugins is installed on the site. The page is in the projection phase..
Support Team posted this 17 May 2017
Hello Martinez ,
please submit new private topic where provide access to the Joomla admin back end.
Hello Martinez , please submit new private topic where provide access to the Joomla admin back end. regards, Aileen
Tommivi
Tommivi posted this 22 June 2017
Hi, this is really strange with beta update. I installed a page withe latest Version 2 weeks ago on my server and exported to another Hosting company. Now i can not start theme here and also i got no backups. So right now there's no access to install updates:-(
How can i get Beta update or fixed files on that version to get system running. ?
Hi, this is really strange with beta update. I installed a page withe latest Version 2 weeks ago on my server and exported to another Hosting company. Now i can not start theme here and also i got no backups. So right now there's no access to install updates:-( How can i get Beta update or fixed files on that version to get system running. ?
Support Team posted this 22 June 2017
Strange that there is no theme saved as back up in the admin panel. Please download the current theme from the FTP and attach it to the ticket.
Hi, Strange that there is no theme saved as back up in the admin panel. Please download the current theme from the FTP and attach it to the ticket. Sincerely, Hella
