posted this
02 May 2017
You work on Mac, right? Please make sure to backup all the created themes from the folder on your computer, the path is shown in the Theme Management screen after selecting some CMS. Or click Go >> Go to Folder >> type ~/Library
and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder. Please try completely uninstalling Themler and also remove Themler folder from the Mac library. Then temporarily disable antivirus and firewall, download and install Themler for Mac anew.
As a temporary solution, you may copy the theme manually from the mentioned folder with themes, zip the theme and install on your hosted website.
You work on Mac, right? Please make sure to backup all the created themes from the folder on your computer, the path is shown in the Theme Management screen after selecting some CMS. Or click Go >> Go to Folder >> type `~/Library` and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder. Please try completely uninstalling Themler and also remove Themler folder from the Mac library. Then temporarily disable antivirus and firewall, download and install Themler for Mac anew.
