Hover Box link not opening in iphone 4
Paul T
Paul T posted this 03 May 2017
I am using hover boxes on my site with links to other pages. This works fine in all cases except iphone 4. In iphone 4 the hover effect works but when you tap it doesn't open the link. In iphone 5 it works fine.
Do you know if this is a know bug in iphone 4 or if there is a work around?
The site is Joomla 3.7.0 Themler v.370
I am using hover boxes on my site with links to other pages. This works fine in all cases except iphone 4. In iphone 4 the hover effect works but when you tap it doesn't open the link. In iphone 5 it works fine. Do you know if this is a know bug in iphone 4 or if there is a work around? The site is Joomla 3.7.0 Themler v.370
Support Team posted this 03 May 2017
I assume that that is the issue of the old Safari version as it works fine on the modern iOS versions.
Hi, I assume that that is the issue of the old Safari version as it works fine on the modern iOS versions. Sincerely, Hella
Paul T
Okay thanks
Okay thanks
You are welcome. Let us know if you need our further help.
You are welcome. Let us know if you need our further help. Sincerely, Hella
