i have bought the themler PRo , but i have not received yet the licence key .
M SAHI
M SAHI
For Themler no license code is required. Just log in with your email and password in the top right corner. With an active subsctiption you should be able to save and export themes.
So i can't use Thelmer pro if i have 'nt internet's connexion ??
and if i havn't an active subscription i can't save and export the themes ??
if i have understand i can make directly a template with the themler pro , or i can install the blank_themler on my joomla template for put the modifications ??
what'"s the utilities of blank_themler_joomla , and blank_themler_prestadhop......
M SAHI
Exactly, Themler requires active internet connection for work.
To use Themler, there are several options:
1. Install Themler. At http://themler.com/download choose a corresponding option - Themler for Windows or Themler for Mac. Just sign in, select CMS and create a theme. You can export a theme at any time as .zip and install in your CMS and continue working at it.
2. Download default theme .zip. At http://themler.com/download choose CMS and click "Themler for [CMS name]" and install it in your CMS. Then select "Themler" in CMS admin and work at the theme.
