Drupal - How to install theme.
lht.shop
lht.shop posted this 06 June 2015
Drupal - How to install theme. I just purchased a theme for Drupal. https://templates.themler.com/Themes/Detail/1872632/Bicycle-Club.
I am an experienced Drupal developer so my question is specific to the installation process of the theme. There are no directions included or help included with the theme other than waht I would normally do for a Drupal theme. But apparently there is more to it than that.
As per standard Drupal practice, I have enabled the theme. However, only a portion of the theme elements seem to be available. I noticed that there was a module that came with the theme, so I installed and enabled that. Supposedly it was to install part of theme's art content; however, it did not seem to accomplish anything. I was expecting it to create blocks of content to fill in the regions in the theme layout.
Is there any moer help on line about this process?
Drupal - How to install theme. I just purchased a theme for Drupal. https://templates.themler.com/Themes/Detail/1872632/Bicycle-Club. I am an experienced Drupal developer so my question is specific to the installation process of the theme. There are no directions included or help included with the theme other than waht I would normally do for a Drupal theme. But apparently there is more to it than that. As per standard Drupal practice, I have enabled the theme. However, only a portion of the theme elements seem to be available. I noticed that there was a module that came with the theme, so I installed and enabled that. Supposedly it was to install part of theme's art content; however, it did not seem to accomplish anything. I was expecting it to create blocks of content to fill in the regions in the theme layout. Is there any moer help on line about this process?
Support Team posted this 08 June 2015
Please make sure you've checked our docs section. There is a tutorial for installing Drupal theme:
http://answers.themler.com/articles/3727/how-to-install-drupal-theme
Also check other docs. They may be helpful.
http://answers.themler.com/categories/3911/drupal-3
Ivan
Hi, Please make sure you've checked our docs section. There is a tutorial for installing Drupal theme: http://answers.themler.com/articles/3727/how-to-install-drupal-theme Also check other docs. They may be helpful. http://answers.themler.com/categories/3911/drupal-3 Please let us know if you have any further questions. Thanks, Ivan
michelle5
michelle5 posted this 12 August 2015
I followed the directions to install the inetco drupal theme.
When I click Apperance-Settings-Edit Theme; I just get a blank page, nothing seems to happen.
I followed the directions to install the inetco drupal theme. When I click Apperance-Settings-Edit Theme; I just get a blank page, nothing seems to happen.
Support Team posted this 13 August 2015
Could you please create a new private ticket and provide us with a temp access to your Drupal back-end there so we can try to help you.
Ivan
Hi, Could you please create a new private ticket and provide us with a temp access to your Drupal back-end there so we can try to help you. Thanks, Ivan
stephen17
stephen17 posted this 13 January 2016
Hi lht.shop, I'm hoping you found the answer to your issue and could post it here for us.
I'm in the same predicament. I'm an experienced Drupal developer and Artisteer user for many years. I have exported a Drupal theme from Windows Themler, installed the new theme and module in my D7 site but can't associate any of the design/layout/content I created in Themler with the actual site.
I can appreciate that my site content and theme are separate and that I must reproduce the content on the live site, no problem. However, the slider, my columns and layout, my images with rollover effects don't transfer over. Also not an issue if I have any indication as to how to wire this up on the Drupal end so that they are available as containers to populate.
I've been through all the docs and instructions on Themler and am comfortable using Themler for designing and creating a theme/template - I do like the tool. I have the Themler editor working fine inside of Drupal. I can install the outputted theme on my Drupal site. That about covers the info available. What's not provided and what I can't determine are those critical steps to make the end result website look exactly like the design in Themler and not the empty generic version I started from.
At least Artisteer had a module to import content and provide a starting point that matched the design from which you could build out the website. I have spent days digging into code, getting partial results by copying, editing and pasting code into Drupal, but this is more work than not having Themler - very frustrating, as are the short answers from tech support pointing me back to the info on how to install a theme in Drupal. I got that, that's not the issue, now I need it to look like what I see in Themler on my desktop!.
I'm hoping that I've missed something obvious or some "magic formula" step that clicks this all together. Basically I'm hoping I missed something stupidly obvious. If not, then what appears to be a very nice theming application is, for me at least as a Drupal developer, useless.
Any input or suggestion is very welcome. Please feel free to call me "stupid" if I missed something obvious (after you've pointed out what that is, of course).
Hi lht.shop, I'm hoping you found the answer to your issue and could post it here for us. I'm in the same predicament. I'm an experienced Drupal developer and Artisteer user for many years. I have exported a Drupal theme from Windows Themler, installed the new theme and module in my D7 site but can't associate any of the design/layout/content I created in Themler with the actual site. I can appreciate that my site content and theme are separate and that I must reproduce the content on the live site, no problem. However, the slider, my columns and layout, my images with rollover effects don't transfer over. Also not an issue if I have any indication as to how to wire this up on the Drupal end so that they are available as containers to populate. I've been through all the docs and instructions on Themler and am comfortable using Themler for designing and creating a theme/template - I do like the tool. I have the Themler editor working fine inside of Drupal. I can install the outputted theme on my Drupal site. That about covers the info available. What's not provided and what I can't determine are those critical steps to make the end result website look exactly like the design in Themler and not the empty generic version I started from. At least Artisteer had a module to import content and provide a starting point that matched the design from which you could build out the website. I have spent days digging into code, getting partial results by copying, editing and pasting code into Drupal, but this is **more work than not having Themler** - very frustrating, as are the short answers from tech support pointing me back to the info on how to install a theme in Drupal. I got that, that's not the issue, now I need it to look like what I see in Themler on my desktop!. I'm hoping that I've missed something obvious or some "magic formula" step that clicks this all together. Basically I'm hoping I missed something stupidly obvious. If not, then what appears to be a very nice theming application is, for me at least as a Drupal developer, useless. Any input or suggestion is very welcome. Please feel free to call me "stupid" if I missed something obvious (after you've pointed out what that is, of course).
Support Team posted this 14 January 2016
Hi Stephen,
I'll answer you in your Private topic.
Hi Stephen, I'll answer you in your Private topic. Thank you, Olivia
