prestashop theme installation
marco.marino1971
marco.marino1971 posted this 18 May 2017
I am trying to install one of your prestashop theme on a site
My Version of prestashop is: 1.6.1.13
I found this problems following your documentation for themler theme installation:
1) There is no import/export module available in modules section. So tried to download the module here: https://addons.prestashop.com/en/page-customization/1713-.html
But compatibility is for v1.3.0.0 - v1.5.6.3 and not for 1.6.x prestashop modules
2) So I am trying to install theme without the import/export module.
And as you explain in documentation I exported your theme (this one: http://templates.themler.com/Themes/Detail/2337516/Shoponym?selectedCms=PrestaShop&statisticsID=99413406&containsInPage=False)
I unzipped the theme and got these folders:
"1.5.3", "1.5.6", "mosules", "themes" and 1 config file (see screenshot)
There is no folder referred to 1.6.1, that is my prestashop version.
So which folders shoud I upload to my ftp?
Marco
Hi, I am trying to install one of your prestashop theme on a site My Version of prestashop is: 1.6.1.13 I found this problems following your documentation for themler theme installation: 1) There is no import/export module available in modules section. So tried to download the module here: https://addons.prestashop.com/en/page-customization/1713-.html But compatibility is for v1.3.0.0 - v1.5.6.3 and not for 1.6.x prestashop modules 2) So I am trying to install theme without the import/export module. And as you explain in documentation I exported your theme (this one: http://templates.themler.com/Themes/Detail/2337516/Shoponym?selectedCms=PrestaShop&statisticsID=99413406&containsInPage=False) I unzipped the theme and got these folders: "1.5.3", "1.5.6", "mosules", "themes" and 1 config file (see screenshot) There is no folder referred to 1.6.1, that is my prestashop version. So which folders shoud I upload to my ftp? Regards Marco
Support Team posted this 18 May 2017
Hello Marco,
Just tried unpacking the theme from http://templates.themler.com/Themes/Detail/2337516?downloadUrl=%2fResource%2fDownload%2f2337516%3fstatisticsID%3d99413406%26actionType%3dDownload and there is a folder /1.6 as well. If there is no such folder, please try to re-download the theme zip.
As for the Import/Export module, the version from https://addons.prestashop.com/en/page-customization/1713-.html should fit 1.6 as well.
Hello Marco, Just tried unpacking the theme from http://templates.themler.com/Themes/Detail/2337516?downloadUrl=%2fResource%2fDownload%2f2337516%3fstatisticsID%3d99413406%26actionType%3dDownload and there is a folder `/1.6` as well. If there is no such folder, please try to re-download the theme zip. As for the Import/Export module, the version from https://addons.prestashop.com/en/page-customization/1713-.html should fit 1.6 as well. Sincerely, Nettie, BillionDigital Team
