Please send me a link that has a tutorial to work with the mouse over option to look like text and image effects.
Att..
Amilcar
Att..
Amilcar
The controls which supports hover effect (like Button or Icon) has appropriate option in Themler UI:
If there is no corresponding option in Themler UI then Themler does not support hover state for this control.
Unfortunately Text and Image controls do not have hover state settings.
Hello, I need a rollover image effect and the icon method is a good option but the transition does not do anything. I would like some fade between the images. Does this only work with icon files?
Is there another way to do this instead?
Hello, I need a rollover image effect and the icon method is a good option but the transition does not do anything. I would like some fade between the images. Does this only work with icon files? Is there another way to do this instead? ThanksLast edited 18 January 2019 by DaveOzric
