links not clickable
Suske65
Suske65 posted this 08 June 2015
I build a Joomla website in Billionthemes (www.etbmarco.nl). The links i made in the website do not work. See attachment.
I think this is related to the template. Can you help me?
Thanks in advance!
Best regards,
Frans Erinkveld
Hi, I build a Joomla website in Billionthemes (www.etbmarco.nl). The links i made in the website do not work. See attachment. I think this is related to the template. Can you help me? Thanks in advance! Best regards, Frans Erinkveld
Support Team posted this 08 June 2015
Could you please provide us with an access to the jomla admin panel so we can check the theme?
Hello Could you please provide us with an access to the jomla admin panel so we can check the theme? Thank you, Olivia
Suske65
User: Billion
Password: themes2015
User: Billion Password: themes2015
For some reason the "Fix on Scroll" Extensions is configured to fix menu at the bottom of the page:
To avoid this the position of the extension wrapper were changed to top manually under the Shape Options >> Arrange (top and bottom have 0 value). As the result the Extension's wrapper covers the whole page.
Please change "Clip at control" and "Fix at screen" to Top and cleanup top and bottom values under Shape Options >> Arrange. This should help.
Thank you, For some reason the "Fix on Scroll" Extensions is configured to fix menu at the bottom of the page: !hmenu-affix.png! To avoid this the position of the extension wrapper were changed to top manually under the Shape Options >> Arrange (*top* and *bottom* have *0* value). As the result the Extension's wrapper covers the whole page. Please change "Clip at control" and "Fix at screen" to *Top* and cleanup *top* and *bottom* values under Shape Options >> Arrange. This should help. Thank you, Olivia
Suske65
That did the job! Thanks a lot for your fast and correct response!
best regards,
Frans Erinkveld
That did the job! Thanks a lot for your fast and correct response! best regards, Frans Erinkveld
You're welcome!
You're welcome!
