WooCommerce Cart Shipping columns and cart old version
lukasz93xx
lukasz93xx posted this 22 May 2017
Wordpress v4.7.5
WooCommerce v3.0.7
I have 3 problems.
  1. Shipping options are placed in 2 cols. First one is empty and in second are placed shipping options. I can't change it. I want to have shipping options in one column 100% of container.
  2. Translations are planned for another version of cart.php file lines numbers - in effect it doesn't work.
  3. [templatename]/woocommerce/cart/cart.php version 2.3.8 is outdated. Base version is 3.0.3,
    [templatename]/woocommerce/loop/result-count.php version 2.0.0 is outdated. Base version is 3.0.0,
    [templatename]/product-searchform.php version - is outdated. Base version is 2.5.0,
Please, help me as fast as you can.
Hello, Wordpress v4.7.5 WooCommerce v3.0.7 I have 3 problems. 1. Shipping options are placed in 2 cols. First one is empty and in second are placed shipping options. I can't change it. I want to have shipping options in one column 100% of container. 2. Translations are planned for another version of cart.php file lines numbers - in effect it doesn't work. 3. [templatename]/woocommerce/cart/cart.php version 2.3.8 is outdated. Base version is 3.0.3, [templatename]/woocommerce/loop/result-count.php version 2.0.0 is outdated. Base version is 3.0.0, [templatename]/product-searchform.php version - is outdated. Base version is 2.5.0, Please, help me as fast as you can.
Support Team posted this 22 May 2017
Could you please provide us with the link to your website and a screenshot that demonstrates the problem table?
Usually the first column is not empty. Also, Themler theme uses the same table as woocommerce provides. Therefore it should looks the same as with default WP theme.
Woocommerce changes cart translation a little. They are now use different register. We'll fix it in the future Themler updates.
Woocommerce checks the text comment with version number. That's all. This version number and message do not affect anything.
Hi, > Shipping options are placed in 2 cols. First one is empty and in second are placed shipping options. I can't change it. I want to have shipping options in one column 100% of container. Could you please provide us with the link to your website and a screenshot that demonstrates the problem table? Usually the first column is not empty. Also, Themler theme uses the same table as woocommerce provides. Therefore it should looks the same as with default WP theme. > Translations are planned for another version of cart.php file lines numbers - in effect it doesn't work. Woocommerce changes cart translation a little. They are now use different register. We'll fix it in the future Themler updates. > [templatename]/woocommerce/cart/cart.php version 2.3.8 is outdated. Base version is 3.0.3, [templatename]/woocommerce/loop/result-count.php version 2.0.0 is outdated. Base version is 3.0.0, [templatename]/product-searchform.php version - is outdated. Base version is 2.5.0, Woocommerce checks the text comment with version number. That's all. This version number and message do not affect anything. Thank you, Olivia
cora9881
cora9881 posted this 08 February 2025
Are you looking to customize the shipping columns in the WooCommerce cart or restore the old version of the cart layout? Could you clarify whether you're trying to modify the cart template, revert to a previous pico y placa WooCommerce version, or fix an issue with shipping options? Let me know how I can help! 😊
Are you looking to customize the shipping columns in the WooCommerce cart or restore the old version of the cart layout? Could you clarify whether you're trying to modify the cart template, revert to a previous [pico y placa][1] WooCommerce version, or fix an issue with shipping options? Let me know how I can help! 😊 [1]: https://runtporplacaycedula.co/pico-y-placa/
yiwaki8545
yiwaki8545 posted this 03 December 2025
Utilize your browser's developer tools (right-click and choose "Inspect" or press F12) to examine the HTML structure of the shipping options wordle hint. Locate the container that contains the shipping options and examine its structure.
Utilize your browser's developer tools (right-click and choose "Inspect" or press F12) to examine the HTML structure of the shipping options [wordle hint][1]. Locate the container that contains the shipping options and examine its structure. [1]: https://wordlehint.io/
mrjackiop3
mrjackiop3 posted this 31 March 2026
La consulta vehicular permite acceder a información relevante sobre un vehículo, como su estado legal, historial, vigencia de documentos y posibles reportes. Realizar esta verificación de forma periódica ayuda a tomar decisiones informadas y a garantizar el cumplimiento de las normativas de tránsito.
La [consulta vehicular][1] permite acceder a información relevante sobre un vehículo, como su estado legal, historial, vigencia de documentos y posibles reportes. Realizar esta verificación de forma periódica ayuda a tomar decisiones informadas y a garantizar el cumplimiento de las normativas de tránsito. [1]: https://runtporplacaa.com.co/
xeniko8001
xeniko8001 posted this 29 September 2026
I will tell your friends to visit this site. .Thanks for the article.ดูหนังเอ็กซ์.live
