Size of images
Amilcar Botelho Rubim Junior
Amilcar Botelho Rubim Junior posted this 23 May 2017
http://www.discotecapublica.com.br/site/
In the link above I can not set the images all of the same size (1), it looks like it has a ratio of the total space of the columns to the size of the images.
And there is also another space between the images that I would like to reduce and it is not possible (2).
Att..
Amilcar
http://www.discotecapublica.com.br/site/ In the link above I can not set the images all of the same size (1), it looks like it has a ratio of the total space of the columns to the size of the images. And there is also another space between the images that I would like to reduce and it is not possible (2). Att.. Amilcar
I have several rows of columns, each within different sections, and when trying to make some changes in the sizes mainly in the width of the image I'm working on (using proportion), this image aligns with the width of the image below and the measurements do not work Informed
But I have to do line by line to see the result and do in the lines below one by one.
Att..
Amilcar
In the link above I can not set the images all of the same size (1), it looks like it has a ratio of the total space of the columns to the size of the images. And there is also another space between the images that I would like to reduce and it is not possible (2). I have several rows of columns, each within different sections, and when trying to make some changes in the sizes mainly in the width of the image I'm working on (using proportion), this image aligns with the width of the image below and the measurements do not work Informed But I have to do line by line to see the result and do in the lines below one by one. Att.. Amilcar
Support Team posted this 24 May 2017
At first, Columns control does not support 5 columns of equal width. You can make 4 or 6. In both cases you can set Image width to 100% and height to auto to stretch the image to the column width. The image will be resized proportionally.
If you want exactly 5 images in the line you can add them into the Container and set image width in %%. But in this case you should count the %% with taking into account the space between images (usually this is margin).
Hi, At first, Columns control does not support 5 columns of equal width. You can make 4 or 6. In both cases you can set Image width to `100%` and height to `auto` to stretch the image to the column width. The image will be resized proportionally. If you want exactly 5 images in the line you can add them into the Container and set image width in %%. But in this case you should count the %% with taking into account the space between images (usually this is margin). Thank you, Olivia
