Virtuemart doesn't show products in catagorie
williamvanveen1988
williamvanveen1988 posted this 25 May 2017
Dear Support,
I don't show anny products in the catgorie. I have here 2 products but doesnt show up. See the link: https://www.wveen.com/wd2/ons-assortiment/dart/dartborden/bulls
In this catagorie i have 2 products but it's tottaly emty
Kind regards,
William
Dear Support, I don't show anny products in the catgorie. I have here 2 products but doesnt show up. See the link: https://www.wveen.com/wd2/ons-assortiment/dart/dartborden/bulls In this catagorie i have 2 products but it's tottaly emty Kind regards, William
8 Comments
Support Team posted this 25 May 2017
Does it work with the non-Themler theme? If yes, then provide an access to the site back end.
Hi, Does it work with the non-Themler theme? If yes, then provide an access to the site back end. Sincerely, Hella
juris.joksts
juris.joksts posted this 29 May 2017
Hello - same probem here (joomla)!! With default beez3 themplate everything is fine, but Themler themplate no products showing in category!
Looked at williamvanveen1988 page - seems he managed that....
Hello - same probem here (joomla)!! With default beez3 themplate everything is fine, but Themler themplate no products showing in category! Looked at williamvanveen1988 page - seems he managed that....
juris.joksts
Resolved... it is themler bug and resolved in Beta version v.373
Support Team posted this 29 May 2017
Yes, indeed, the issue was resolved in the latest version. Please enable beta updates in your account settings and then update the theme to the lateset beta version.
Hi, Yes, indeed, the issue was resolved in the latest version. Please enable beta updates in your account settings and then update the theme to the lateset beta version. Sincerely, Hella
williamvanveen1988
Is Solution
williamvanveen1988 posted this 29 May 2017
Hey People,
In Virtuemart. Same problem on the standart theme.
To solve you need to do the following:
Menu setup:
Catgory view in menu setup to view product and standaart to show products, also don't forget to setup the row numbers.
Kind regards
William
Hey People, In Virtuemart. Same problem on the standart theme. To solve you need to do the following: Menu setup: Catgory view in menu setup to view product and standaart to show products, also don't forget to setup the row numbers. Kind regards William
Hi William,
Thanks for sharing the way to set it up correctly in Virtuemart. Also make sure to update Themler to the latest Beta to have the products disaplayed correctly.
Hi William, Thanks for sharing the way to set it up correctly in Virtuemart. Also make sure to update Themler to the latest Beta to have the products disaplayed correctly. Sincerely, Nettie, BillionDigital Team
ny_acs_gh
ny_acs_gh posted this 26 June 2017
Hi all
I have the same problem as williamvanveen1988 postet before.
My actual versions are:
Themler: v.397
Joomla: 3.7.2.
Virtuemart: 3.2.3
My website is: http://www.gluehwein.ch/shop/kategorien/likoer-gluehwein-weine-destillate
I thougt, this problem would have been fixed after Update v.397, but it seems the problem still exists.
Can you please help me?
Thanks and best regards,
Remo
Hi all I have the same problem as williamvanveen1988 postet before. My actual versions are: Themler: v.397 Joomla: 3.7.2. Virtuemart: 3.2.3 My website is: http://www.gluehwein.ch/shop/kategorien/likoer-gluehwein-weine-destillate I thougt, this problem would have been fixed after Update v.397, but it seems the problem still exists. Can you please help me? Thanks and best regards, Remo
Support Team posted this 26 June 2017
Hello Remo,
Could you please create a new private topic and provide temporary access to your website for ivnestgation?
Hello Remo, Could you please create a new private topic and provide temporary access to your website for ivnestgation? Sincerely, Nettie, BillionDigital Team
