Footer mashing into section above on mobile display.
visAdhvasa
visAdhvasa posted this 26 May 2017
Please have a look at my template and explain why the following is happening:
(Attachment)
This only happens in the mobile display.
Footer section.
bebliss.yoga
Please tell me how to stop it.
Please have a look at my template and explain why the following is happening: (Attachment) This only happens in the mobile display. Footer section. bebliss.yoga Please tell me how to stop it.
6 Comments
Support Team posted this 26 May 2017
The section above the footer has the fixed height value set to 400px. Remove it and then the layout should be fine.
Hi, The section above the footer has the fixed height value set to 400px. Remove it and then the layout should be fine. Sincerely, Hella
visAdhvasa
Hi Hella,
I want the section above to have that height, and there are no limits on the size of a page. The section height was set in laptop mode, not mobile mode.
The footer should always be stuck to the bottom, and in fact, I chose that setting.
So please give me another way to fix it, or fix it for me.
And explain how to make different settings for laptop and mobile views.
Hi Hella, I want the section above to have that height, and there are no limits on the size of a page. The section height was set in laptop mode, not mobile mode. The footer should always be stuck to the bottom, and in fact, I chose that setting. So please give me another way to fix it, or fix it for me. And explain how to make different settings for laptop and mobile views.
OK, then open the page in Themler and switch to the phone view and set the height for that section to auto. Let me know if that helps.
Hi, OK, then open the page in Themler and switch to the phone view and set the height for that section to auto. Let me know if that helps. Sincerely, Hella
online9
online9 posted this 24 October 2019
I have the same problem on a customer's Joomla site. The page I am working on to find a solution is at http://palliserridge.co.nz/the-gazing-places-nga-matakitaki/kaikoura-lookout-matakitaki-kaikoura/
This problem is evident on all 'page' template pages. The home page is not affected to the same degree.
They are maintaining it themselves and have asked me to look into this problem.
If I disable the footer, the backlink section still overwrites the central section. If I disable that for mobile then there's no problem, but the customer wants the footer section to appear on all 'page's. I could kill the footer and add the contact info on each page, but that is not a good solution for future pages.
I have have tried setting the section that the footer is overwriting as auto height but that makes no change
I have inspected the layout and can see no mobile settings that would cause this.
I have tried about every other adjustment and setting on all the elements that I can think of and have run out of ideas.
Can you give me some other hints please?
Everything works fine in all other display modes, but as soon as I move to mobile, the layout breaks.
The central section containing the text is overwritten by the footer and backlink blocks.
Hi I have the same problem on a customer's Joomla site. The page I am working on to find a solution is at http://palliserridge.co.nz/the-gazing-places-nga-matakitaki/kaikoura-lookout-matakitaki-kaikoura/ This problem is evident on all 'page' template pages. The home page is not affected to the same degree. They are maintaining it themselves and have asked me to look into this problem. If I disable the footer, the backlink section still overwrites the central section. If I disable that for mobile then there's no problem, but the customer wants the footer section to appear on all 'page's. I could kill the footer and add the contact info on each page, but that is not a good solution for future pages. I have have tried setting the section that the footer is overwriting as auto height but that makes no change I have inspected the layout and can see no mobile settings that would cause this. I have tried about every other adjustment and setting on all the elements that I can think of and have run out of ideas. Can you give me some other hints please? Everything works fine in all other display modes, but as soon as I move to mobile, the layout breaks. The central section containing the text is overwritten by the footer and backlink blocks.
frederickgragg
frederickgragg posted this 30 September 2024
Elevate your Azure expertise with our comprehensive Microsoft AZ-305 Dumps Questions. Designed for aspiring Azure Solutions Architects, these resources provide real exam questions and detailed answers to ensure you’re fully prepared. Our dumps cover essential topics, including designing identity and security, data storage solutions, and business continuity strategies.
With our carefully curated materials, you can enhance your understanding of Azure architecture and services. Each question reflects the latest exam trends, giving you confidence as you approach your certification.
Join countless successful candidates who have utilized our AZ-305 dumps to achieve their certification goals. Don’t leave your success to chance—invest in your future and gain the skills needed to excel in the cloud computing landscape.
Elevate your Azure expertise with our comprehensive [**Microsoft AZ-305 Dumps Questions**][1]. Designed for aspiring Azure Solutions Architects, these resources provide real exam questions and detailed answers to ensure you’re fully prepared. Our dumps cover essential topics, including designing identity and security, data storage solutions, and business continuity strategies. With our carefully curated materials, you can enhance your understanding of Azure architecture and services. Each question reflects the latest exam trends, giving you confidence as you approach your certification. Join countless successful candidates who have utilized our AZ-305 dumps to achieve their certification goals. Don’t leave your success to chance—invest in your future and gain the skills needed to excel in the cloud computing landscape. [1]: https://www.dumpsjournal.com/Exam/AZ-305-dumps.html
teraboxmoddapk1
teraboxmoddapk1 posted this 18 December 2024
Mobile display issues like a footer overlapping can be frustrating. While fixing the issue, you can back up your website files using TeraBox MOD APK Premium Unlocked, which provides 1TB of storage to keep your data safe during troubleshooting.
Mobile display issues like a footer overlapping can be frustrating. While fixing the issue, you can back up your website files using [TeraBox MOD APK Premium Unlocked][1], which provides 1TB of storage to keep your data safe during troubleshooting. [1]: https://teraboxmoddapk.com/
