Themler v.367 fails to export zip file. It seems to go through ok, but it is not saved anywhere on my HD.
Themler v.367 fails to export zip file. It seems to go through ok, but it is not saved anywhere on my HD.Themler v.367 fails to export zip file. It seems to go through ok, but it is not saved anywhere on my HD.
Themler v.367 fails to export zip file. It seems to go through ok, but it is not saved anywhere on my HD.Hi,
Themler exports archive to the default browser downloads directory.
Could you please try exporting file to the desktop for testing. Does the issue continue?
Also try running Themer directly in browser using the following link and export theme:
http://127.0.0.1:29958/themler_3453727911/drupal/
admin/admin
OK, I found where I can load themler.. from the theme edit button. However, it gives me the same experience as the desktop version. It does not export the theme.
OK, I found where I can load themler.. from the theme edit button. However, it gives me the same experience as the desktop version. It does not export the theme.OK, so with some more fiddling it WILL export fro Chrome. It will not from Safari. I will test loading it into my external drupal install and see what happens. Thanks.
OK, so with some more fiddling it WILL export fro Chrome. It will not from Safari. I will test loading it into my external drupal install and see what happens. Thanks.Hi,
Please check Safari settings. There should be an option to change the downloads folder or enable option to ask where to download.
