Error showing when i uploading wordpress
updeshhw
updeshhw posted this 04 June 2017
Hi! Kindly solve this issue when i start wordpress then it says "Sorry, error occurred. Your project will be restored." and after long wait it does not clear. I also restart the laptop but still the issue is there. Sending you the log file kindly check and do the needful.
regards
Updeshh
Hi! Kindly solve this issue when i start wordpress then it says "Sorry, error occurred. Your project will be restored." and after long wait it does not clear. I also restart the laptop but still the issue is there. Sending you the log file kindly check and do the needful. regards Updeshh
Support Team posted this 05 June 2017
7. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for aWordpress and create a theme.
Hello, Please follow the steps below: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for aWordpress and create a theme. Please let us know the result. Sincerely, Nettie, BillionDigital Team
