I Have a Module position in a column inside the (Header bar) All Templates container. I don't want the Module to interfere with the header bar. i.e affect the height the of the header bar container
If you look at Amazon.com (image attached
2017-06-04--2-.png)
clicking on the Departments menu blurs out the background or creates an overlay. How do I get Themler to work the same way? When I put a menu module in that position it pushes the whole height of the Header bar further down.
Picture 2017-06-04--2-.png is how mine displays
I Have a Module position in a column inside the (Header bar) All Templates container. I don't want the Module to interfere with the header bar. i.e *affect the height the of the header bar container* If you look at Amazon.com (image attached 2017-06-04--2-.png) clicking on the Departments menu blurs out the background or creates an overlay. How do I get Themler to work the same way? When I put a menu module in that position it pushes the whole height of the Header bar further down. Picture 2017-06-04--2-.png is how mine displays
