Pages only show html-code, both in visual and text editor of Wordpress
mail278
mail278 posted this 10 June 2017
I have been making a template in Themler and exported this as a zip-file with content checked and Themler unchecked.
After that I have Imported the theme into Wordpress and via the Themler plugin imported the content from the theme.
So far so good.
However, when I open a page in Wordpress, both in the visual and in the text editor, I only see HTML coding.
I was expecting to see something else in the visual editor, because this is non usable for an end user without any knowledge of html.
I have been reading lots of topics, but cannot find the answer to this specific question. I am using the updated version as of today Juni 10th 2017.
Thanks to anyone who can help me to figure this out.
Hello, I have been making a template in Themler and exported this as a zip-file with content checked and Themler unchecked. After that I have Imported the theme into Wordpress and via the Themler plugin imported the content from the theme. So far so good. However, when I open a page in Wordpress, both in the visual and in the text editor, I only see HTML coding. I was expecting to see something else in the visual editor, because this is non usable for an end user without any knowledge of html. I have been reading lots of topics, but cannot find the answer to this specific question. I am using the updated version as of today Juni 10th 2017. Thanks to anyone who can help me to figure this out.
25 Comments
johnsmak404
johnsmak404 posted this 29 June 2026
Thanks for bringing this up. This is actually a common situation when working with page builders or theme generators that export static HTML into WordPress.
In many cases, when a template is exported from tools like Themler, the page content is stored as HTML rather than as editable WordPress blocks or native editor elements. As a result, both the Visual and Text editors display the underlying HTML markup instead of a drag-and-drop or WYSIWYG editing experience. While the page may look perfectly fine on the frontend, it isn't very user-friendly for clients or website owners who aren't comfortable editing HTML.
A few things are worth checking:
  • Verify that the content was exported in a format intended for WordPress editing and not as static HTML.
  • Make sure the latest version of both the theme and the Themler plugin are installed and compatible with your WordPress version.
  • Check whether the page is designed to be edited through Themler itself rather than directly inside the WordPress editor.
  • If the template relies on shortcodes or a proprietary page builder, editing the raw HTML in WordPress may be the expected behavior.
From my experience building WordPress websites for businesses, it's always better to use page builders or block-based editors that allow non-technical users to update text, images, and layouts without touching code. Many service businesses, including companies offering pest control services, need websites that staff members can easily maintain. A good example is https://etihadbluepestcontrol.com/, where a clean, user-friendly website structure makes it much easier to update service pages and publish new content without requiring HTML knowledge.
Ultimately, if your goal is to hand the website over to an end user, I'd recommend using a solution that supports true visual editing rather than storing the entire page as HTML. That creates a much better editing experience and significantly reduces the risk of accidental code changes.
Thanks for bringing this up. This is actually a common situation when working with page builders or theme generators that export static HTML into WordPress. In many cases, when a template is exported from tools like Themler, the page content is stored as HTML rather than as editable WordPress blocks or native editor elements. As a result, both the Visual and Text editors display the underlying HTML markup instead of a drag-and-drop or WYSIWYG editing experience. While the page may look perfectly fine on the frontend, it isn't very user-friendly for clients or website owners who aren't comfortable editing HTML. A few things are worth checking: * Verify that the content was exported in a format intended for WordPress editing and not as static HTML. * Make sure the latest version of both the theme and the Themler plugin are installed and compatible with your WordPress version. * Check whether the page is designed to be edited through Themler itself rather than directly inside the WordPress editor. * If the template relies on shortcodes or a proprietary page builder, editing the raw HTML in WordPress may be the expected behavior. From my experience building WordPress websites for businesses, it's always better to use page builders or block-based editors that allow non-technical users to update text, images, and layouts without touching code. Many service businesses, including companies offering [pest control services][1], need websites that staff members can easily maintain. A good example is https://etihadbluepestcontrol.com/, where a clean, user-friendly website structure makes it much easier to update service pages and publish new content without requiring HTML knowledge. Ultimately, if your goal is to hand the website over to an end user, I'd recommend using a solution that supports true visual editing rather than storing the entire page as HTML. That creates a much better editing experience and significantly reduces the risk of accidental code changes. [1]: https://etihadbluepestcontrol.com/
walliullahseo
walliullahseo posted this 19 September 2026
I ran into a similar issue when working with WordPress themes and page builders. It sounds like the HTML content is being imported correctly, but the editor isn't interpreting it as visual content, which can definitely be confusing for someone who isn't familiar with HTML. Hopefully you found a solution or an update from Themler that addressed this. I’ve also been working with different online tools and resources lately, including Online Gratuity Calculator
I ran into a similar issue when working with WordPress themes and page builders. It sounds like the HTML content is being imported correctly, but the editor isn't interpreting it as visual content, which can definitely be confusing for someone who isn't familiar with HTML. Hopefully you found a solution or an update from Themler that addressed this. I’ve also been working with different online tools and resources lately, including [Online Gratuity Calculator][1] [1]: https://onlinegratuitycalculator.ae
zentisu727
zentisu727 posted this 30 September 2026
Wet ceilings and walls can retain moisture after leaks or flooding. Ceiling and Wall Drying can help remove trapped moisture and support proper restoration. Basement Water Damage Repair
Wet ceilings and walls can retain moisture after leaks or flooding. Ceiling and Wall Drying can help remove trapped moisture and support proper restoration. [Basement Water Damage Repair][1] [1]: https://waterdamagerestorationfairfax.us/services/basement-water-damage-repair
zentisu727
Prompt restoration can help reduce the impact of water damage after leaks, storms, or flooding. Water Damage Restoration in Arkansas provides support for affected properties.Water Extraction Services
Prompt restoration can help reduce the impact of water damage after leaks, storms, or flooding. Water Damage Restoration in Arkansas provides support for affected properties.[Water Extraction Services][1] [1]: https://aquarestorepro.us/services/water-extraction-services
zentisu727
Routine gutter cleaning services across Arkansas can help prevent buildup and improve water flow. Arkansas Gutter Cleaning Experts
Routine gutter cleaning services across Arkansas can help prevent buildup and improve water flow. [Arkansas Gutter Cleaning Experts][1] [1]: https://little-rock-ar.thegutterpros.us/gutter-sealing-and-caulking
