Please wait...Themler Diagnostics Log
Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket.
INFO:Version files finded:
INFO: C:\PROGRA~3\Themler\1.0.319.25.ver
INFO:Check free disk space...
INFO:Check Services...
ERROR:Apache service isn't started
INFO:Check Files...
ERROR:Can't find path C:\PROGRA~3\Themler\db_data (DB_DATA_DIR)
INFO:Check HTTP Server...
INFO:Check INI Files...
INFO:No errors!
======== Content of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
Program files detected C:\Program Files (x86)
Must be on program files\themler\bin
Le volume dans le lecteur C n'a pas de nom.
Le num�ro de s�rie du volume est 6AC7-661C
R�pertoire de C:\Program Files (x86)\Themler\bin
12/06/2017 16:42 <dir> .
12/06/2017 16:42 <dir> ..
12/06/2017 16:42 <dir> 7zip
12/06/2017 16:42 <dir> apache
12/06/2017 16:42 <dir> diagnostics
22/06/2016 13:18 1�402 install-apache.bat
22/06/2016 13:18 2�724 install-mysql.bat
12/06/2017 16:42 <dir> mysql
12/06/2017 16:42 <dir> php
22/06/2016 13:18 1�730 uninstall-apache.bat
22/06/2016 13:18 1�695 uninstall-mysql.bat
12/06/2017 16:42 <dir> _logs
4 fichier(s) 7�551 octets
8 R�p(s) 123�577�352�192 octets libres
creating logs just in case
Un sous-r�pertoire ou un fichier C:\ProgramData\Themler existe d�j�.
Created
Installin
8 R�p(s) 123�569�790�976 octets libres
Un sous-r�pertoire
======== End of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log
ERROR:Unable to find file C:\Users\Hocine Aguemmoune\AppData\Local\Themler\Themler_vbs.log
ERROR:Unable to find file C:\ProgramData\Themler\logs\startup.php.log
ERROR:Unable to find file C:\ProgramData\Themler\logs\apache\error.log
ERROR:Unable to find file C:\ProgramData\Themler\logs\apache\access.log
ERROR:Unable to find file C:\ProgramData\Themler\logs\mysql\error.log
======== Content of file C:\Users\Hocine Aguemmoune\AppData\Local\Temp\themler_install.log ========
Starting onInit...
Starting uninstaller...
Uninstaller started
Starting onInit...
Calculating user folders for install...
Users folder for install calculated
onInit finished...
Starting main...
Copying cms data...
CMS data copied
Copying rest of files...
Rest of files copied
Copying dumps...
Dumps copied
Main finished
Adding firewall rules...
Firewall rules added
Replacing config files...
Config files replaced
Installing MySql...
MySql installed
Installing apache service...
Apache service installed
Creating link and icons...
Icons and links created...
Opening control panel...
Control panel opened
Creating shorcut...
Shortcut created
Starting onInit...
onInit finished...
Starting main...
Copying cms data...
CMS data copied
Copying dumps...
Dumps copied
Main finished
Installing MySql...
MySql installed
Creating shorcut...
Shortcut created
======== End of file C:\Users\Hocine Aguemmoune\AppData\Local\Temp\themler_install.log ========
ERROR:Unable to find file C:\Users\Hocine Aguemmoune\AppData\Roaming..\Local\Themler\ChromeData\chrome_debug.log
Please wait...Themler Diagnostics Log Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket. INFO:Version files finded: INFO: C:\PROGRA~3\Themler\1.0.319.25.ver INFO:Check free disk space... INFO:Check Services... ERROR:Apache service isn't started INFO:Check Files... ERROR:Can't find path C:\PROGRA~3\Themler\db_data (DB_DATA_DIR) INFO:Check HTTP Server... INFO:Check INI Files... INFO:No errors! ======== Content of file C:\Program Files (x86)\Themler\bin\_logs\bat_exec.log ======== Program files detected C:\Program Files (x86) Must be on program files\themler\bin Le volume dans le lecteur C n'a pas de nom. Le num�ro de s�rie du volume est 6AC7-661C R�pertoire de C:\Program Files (x86)\Themler\bin 12/06/2017 16:42 <dir> . 12/06/2017 16:42 <dir> .. 12/06/2017 16:42 <dir> 7zip 12/06/2017 16:42 <dir> apache 12/06/2017 16:42 <dir> diagnostics 22/06/2016 13:18 1�402 install-apache.bat 22/06/2016 13:18 2�724 install-mysql.bat 12/06/2017 16:42 <dir> mysql 12/06/2017 16:42 <dir> php 22/06/2016 13:18 1�730 uninstall-apache.bat 22/06/2016 13:18 1�695 uninstall-mysql.bat 12/06/2017 16:42 <dir> _logs 4 fichier(s) 7�551 octets 8 R�p(s) 123�577�352�192 octets libres creating logs just in case Un sous-r�pertoire ou un fichier C:\ProgramData\Themler existe d�j�. Created Installin Program files detected C:\Program Files (x86) Must be on program files\themler\bin Le volume dans le lecteur C n'a pas de nom. Le num�ro de s�rie du volume est 6AC7-661C R�pertoire de C:\Program Files (x86)\Themler\bin 12/06/2017 16:42 <dir> . 12/06/2017 16:42 <dir> .. 12/06/2017 16:42 <dir> 7zip 12/06/2017 16:42 <dir> apache 12/06/2017 16:42 <dir> diagnostics 22/06/2016 13:18 1�402 install-apache.bat 22/06/2016 13:18 2�724 install-mysql.bat 12/06/2017 16:42 <dir> mysql 12/06/2017 16:42 <dir> php 22/06/2016 13:18 1�730 uninstall-apache.bat 22/06/2016 13:18 1�695 uninstall-mysql.bat 12/06/2017 16:42 <dir> _logs 4 fichier(s) 7�551 octets 8 R�p(s) 123�569�790�976 octets libres creating logs just in case Un sous-r�pertoire ou un fichier C:\ProgramData\Themler existe d�j�. Un sous-r�pertoire ======== End of file C:\Program Files (x86)\Themler\bin\_logs\bat_exec.log ======== ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log ERROR:Unable to find file C:\Users\Hocine Aguemmoune\AppData\Local\Themler\Themler_vbs.log ERROR:Unable to find file C:\ProgramData\Themler\logs\startup.php.log ERROR:Unable to find file C:\ProgramData\Themler\logs\apache\error.log ERROR:Unable to find file C:\ProgramData\Themler\logs\apache\access.log ERROR:Unable to find file C:\ProgramData\Themler\logs\mysql\error.log ======== Content of file C:\Users\Hocine Aguemmoune\AppData\Local\Temp\themler_install.log ======== Starting onInit... Starting uninstaller... Uninstaller started Starting onInit... Calculating user folders for install... Users folder for install calculated onInit finished... Starting main... Copying cms data... CMS data copied Copying rest of files... Rest of files copied Copying dumps... Dumps copied Main finished Adding firewall rules... Firewall rules added Replacing config files... Config files replaced Installing MySql... MySql installed Installing apache service... Apache service installed Creating link and icons... Icons and links created... Opening control panel... Control panel opened Creating shorcut... Shortcut created Starting onInit... Calculating user folders for install... Users folder for install calculated onInit finished... Starting main... Copying cms data... CMS data copied Copying rest of files... Rest of files copied Copying dumps... Dumps copied Main finished Adding firewall rules... Firewall rules added Replacing config files... Config files replaced Installing MySql... MySql installed Installing apache service... Apache service installed Creating link and icons... Icons and links created... Opening control panel... Control panel opened Creating shorcut... Shortcut created ======== End of file C:\Users\Hocine Aguemmoune\AppData\Local\Temp\themler_install.log ======== ERROR:Unable to find file C:\Users\Hocine Aguemmoune\AppData\Roaming\..\Local\Themler\ChromeData\chrome_debug.log
