Why can not I log in from my other computer to my account?
info2253
info2253 posted this 15 June 2017
Hi.
I have a laptop and I also work outside my office. I have tried to log in to my account, but I get a message from the wrong name and password ??
What can I do????
KL - Finland
Hi. Why can not I log in from my other computer to my account? I have a laptop and I also work outside my office. I have tried to log in to my account, but I get a message from the wrong name and password ?? What can I do???? KL - Finland
Support Team posted this 15 June 2017
Please make sure that you are entering exactly the same details as in this support account. There should be no such problems.
Hi, Please make sure that you are entering exactly the same details as in this support account. There should be no such problems. Sincerely, Hella
info2253
info2253 posted this 17 June 2017
The problem has been solved. Thank you.
One more problem.
I have made the theme on your desktop computer with Win7. I have tried to bring the theme (html5) laptop computer with Win10. This indicates that the zip file can not be imported. What is the problem?
The problem has been solved. Thank you. One more problem. I have made the theme on your desktop computer with Win7. I have tried to bring the theme (html5) laptop computer with Win10. This indicates that the zip file can not be imported. What is the problem?
Support Team posted this 18 June 2017
If you're trying to import exactly HTML theme then please make sure that you exported HTML theme with Themler. You may encounter the described issue if you exported theme without Themler. Such theme cannot be opened in Themler again.
Hi, If you're trying to import exactly HTML theme then please make sure that you exported HTML theme with Themler. You may encounter the described issue if you exported theme without Themler. Such theme cannot be opened in Themler again. Thank you, Olivia
