Url sufiks / parameter problem with Drupal 7 and Themler.
PrusIT
PrusIT posted this 17 June 2017
I have big problem with my Drupal site (theme generated in Themler).
Google has indexed url addresses with sufiks "?theme=Naddachami". Naddachami is theme name. But I don't understand why there are addresses with ?theme sufiks.
Please see attachment.
Site: https://naddachami.pl
Classic blog site: https://naddachami.pl/blog/dji-spark-premiera-vs-dji-mavic
But Google indexed: https://naddachami.pl/comment/dji-spark-premiera-vs-dji-mavic%3Ftheme%3DNaddachami
or https://naddachami.pl/comment/dji-spark-premiera-vs-dji-mavic?theme=Naddachami
Where is the mistake?
Hi, I have big problem with my Drupal site (theme generated in Themler). Google has indexed url addresses with sufiks "?theme=Naddachami". Naddachami is theme name. But I don't understand why there are addresses with ?theme sufiks. Please see attachment. Site: https://naddachami.pl Classic blog site: https://naddachami.pl/blog/dji-spark-premiera-vs-dji-mavic But Google indexed: https://naddachami.pl/comment/dji-spark-premiera-vs-dji-mavic%3Ftheme%3DNaddachami or https://naddachami.pl/comment/dji-spark-premiera-vs-dji-mavic?theme=Naddachami Where is the mistake?
Support Team posted this 19 June 2017
Themler can open the theme which is not specified as default. In order to preview the website Themler uses ?theme URL parameter to load proper theme.
In order to make google ignore these links you can disallow them in robots.txt file.
https://stackoverflow.com/questions/9149782/ignore-urls-in-robot-txt-with-specific-parameters
Hi, Themler can open the theme which is not specified as default. In order to preview the website Themler uses `?theme` URL parameter to load proper theme. In order to make google ignore these links you can disallow them in robots.txt file. https://stackoverflow.com/questions/9149782/ignore-urls-in-robot-txt-with-specific-parameters Thank you, Olivia
PrusIT
PrusIT posted this 19 June 2017
Thank You, I will try with robots.txt.
> Hi, > > Themler can open the theme which is not specified as default. In order to preview the website Themler uses `?theme` URL parameter to load proper theme. > In order to make google ignore these links you can disallow them in robots.txt file. > https://stackoverflow.com/questions/9149782/ignore-urls-in-robot-txt-with-specific-parameters > > Thank you, > Olivia > > Thank You, I will try with robots.txt.
charliechaplindunnd
charliechaplindunnd posted this 07 October 2024
The?theme= parameter is commonly used in Drupal to enable users to choose between themes bitlife. This may be enabled if users may choose their favorite theme.
The?theme= parameter is commonly used in Drupal to enable users to choose between themes [bitlife][1]. This may be enabled if users may choose their favorite theme. [1]: https://lifesimulator.online/
