How do i reduce the line height for the post header?
See Red highlighted ares, the bit i would like to reduce is the blue area.
Cheers,
Jamie
Cheers,
Jamie
Hi Jamie, go to paragraph - line height, and choose the height you need.
I attached an image for you:)
Have a great day,
Shaul.
Hi Jamie, go to paragraph - line height, and choose the height you need. I attached an image for you:) Have a great day, Shaul.Thank you for your reply, i did check that and it was set to no value, however any value i selected just made the gap bigger.
I tried doing a minus i.e. -1 and that didn't work either.
I have changed the font size to a slightly smaller font now which has made the gap a little smaller but thats not quite what i want.
Cheers,
Jamie
You need to put text, link, hover, etc same font-size in px. Then gap will reduce. Inherit wont help allways. Put font-size in one number, for all options.
You need to put text, link, hover, etc same font-size in px. Then gap will reduce. Inherit wont help allways. Put font-size in one number, for all options.Hi,
Also you can set the smaller value in the Line Height option, like 0.5.
