Download Button
johnmacywade
johnmacywade posted this 23 June 2017
How to Add a Download Button to a Website? Need to turn a button into downloadable word document from a website. how do you do this? I have to word document save a my PC
8 Comments
Support Team posted this 23 June 2017
You need to upload your file to the hosting and then use the button control inside Themler with the link to the file hosted on the web.
Hi, You need to upload your file to the hosting and then use the button control inside Themler with the link to the file hosted on the web. Sincerely, Hella
johnmacywade
Awesome Thank you!
Awesome Thank you!
You are welcome. Please feel free to contact us in any other case.
You are welcome. Please feel free to contact us in any other case. Sincerely, Nettie, BillionDigital Team
Basics in Motion
Basics in Motion posted this 21 March 2018
Can you please elaborate on this? Maybe a screenshot of how to set up the link?
Hello Can you please elaborate on this? Maybe a screenshot of how to set up the link? Thanks
Support Team posted this 21 March 2018
The link should be the direct path to the file to be opened. For this it is sufficient to add a Button control from the Insert tab and add the URL into the Link field.
If you would like namely to add the "download" attribute to the link like https://www.w3schools.com/tags/att_a_download.asp, I would recommend you to consider using HTML control added from the Insert tab >> More. Then you may select the text in the control, make it a button using context menu, add the link, and then click "Edit HTML" to add the "download" attribute to the link.
Hello, The link should be the direct path to the file to be opened. For this it is sufficient to add a Button control from the Insert tab and add the URL into the Link field. If you would like namely to add the "download" attribute to the link like https://www.w3schools.com/tags/att_a_download.asp, I would recommend you to consider using HTML control added from the Insert tab >> More. Then you may select the text in the control, make it a button using context menu, add the link, and then click "Edit HTML" to add the "download" attribute to the link. Sincerely, Nettie, BillionDigital Team
Basics in Motion
Thank you.
Thank you.
You are welcome. Please let us know if any additional questions appear in process.
You are welcome. Please let us know if any additional questions appear in process. Sincerely, Nettie, BillionDigital Team
California Business Journal
California Business Journal posted this 21 May 2025
Find reliable hard money lenders in California and get fast, flexible funding options when traditional financing doesn’t work.
Find reliable [hard money lenders][1] in California and get fast, flexible funding options when traditional financing doesn’t work. [1]: https://calbizjournal.com/complete-list-of-hard-money-lenders-in-california/
