VirtueMart Products Module Instances
enyonam
enyonam posted this 25 June 2017
I have configured Several Instances of VM Product Module and assigned them to different positions on my theme. However, All the instances of VM Products Module, do not show up at the same time. On refresh, some modules show up and others are hidden. When you set Module Titles to show, you'll see all the module titles showing at their respective postions but not the products.
I decided to try this on the Beez3 Template and it All modules show up at their various positions as their supposed to. This forces me to to believe this might be a themler issue. Can you please look into this for me.
Note: All Categories I am trying to display in the various module instances have products published in them. I have attached the beez3 display and my theme's display.
I have configured Several Instances of VM Product Module and assigned them to different positions on my theme. However, All the instances of VM Products Module, do not show up at the same time. On refresh, some modules show up and others are hidden. When you set Module Titles to show, you'll see all the module titles showing at their respective postions but not the products. I decided to try this on the Beez3 Template and it All modules show up at their various positions as their supposed to. This forces me to to believe this might be a themler issue. Can you please look into this for me. Note: All Categories I am trying to display in the various module instances have products published in them. I have attached the beez3 display and my theme's display.
Support Team posted this 26 June 2017
We're aware about this issue. It should be fixed in the future Themler updates.
Hi, We're aware about this issue. It should be fixed in the future Themler updates. Thank you, Olivia
enyonam
enyonam posted this 26 June 2017
How soon will this update be As i Have a project that is stuck because of his problem. I need to display 7 instances of VM products.
Support Team posted this 28 June 2017
Unfortunately we do not have any dates for the update and the issue being fixed now. Please follow the updates.
Hi, Unfortunately we do not have any dates for the update and the issue being fixed now. Please follow the updates. Sincerely, Hella
Support Team posted this 25 July 2017
For now you can switch off the caching for modules (VM cache option in the module settings).
Hi, For now you can switch off the caching for modules (VM cache option in the module settings). Sincerely, Hella
