Cannot run themler, it has only black screen
Jörg Vierling
Jörg Vierling posted this 25 June 2017
I cannot start themler. it comes only a black screen, see picture themler0.jpg.
then i find out my subcription had expired. i renewed it.
then i start themler, but still the black screen.
then i download themler and tryed to install, but it will not because a port adress is blocked. see picture themler1., what should i do?
I cannot start themler. it comes only a black screen, see picture themler0.jpg. then i find out my subcription had expired. i renewed it. then i start themler, but still the black screen. then i download themler and tryed to install, but it will not because a port adress is blocked. see picture themler1., what should i do?
14 Comments
Support Team posted this 26 June 2017
Please check what process is using this port under the Windows Task Manager >> Performance >> Resource Monitor. Maybe it could be possible to stop this process to free the port.
Hi, Please check what process is using this port under the Windows Task Manager >> Performance >> Resource Monitor. Maybe it could be possible to stop this process to free the port. Thank you, Olivia
Jörg Vierling
Jörg Vierling posted this 26 June 2017
but the port is used by Themler, so I can't understand what is wrong.
Maybe the old Themler Version is corupt and blocking this? How can I uninstall it. It not works over the App-Feature in the system controlling.
I use Windows 10
Best regards
Joerg
Thanks, but the port is used by Themler, so I can't understand what is wrong. Maybe the old Themler Version is corupt and blocking this? How can I uninstall it. It not works over the App-Feature in the system controlling. I use Windows 10 Best regards Joerg
The uninstalling of Themler from the Control Panel >> Programs and Features works just fine on my side.
Could you please try again. The process could be slow a little.
In the described situation reinstalling of Themler helps usually.
As alternative please try running Themler using the following link:
http://127.0.0.1:12080/themler_2154048764/startup
Hi, The uninstalling of Themler from the Control Panel >> Programs and Features works just fine on my side. Could you please try again. The process could be slow a little. In the described situation reinstalling of Themler helps usually. As alternative please try running Themler using the following link: http://127.0.0.1:12080/themler_2154048764/startup Please keep us posted about the progress. Thank you, Olivia
Jörg Vierling
Hi Olivia,
thanks for update.
The Themler is not listet at the programs and features in nthe control panel and so i cannot uninstall.
However with your link it works so far ok. Thanks.
An other question. Can I use the pictures from BillionDigital for my customer projects? Do they have to by a license too or is it covered with my account/licence. If so, I do have to menchend them on the website that they are from billiondigital or billionphotos?
And what happend if my acount expired with the rights of the pictures in my clients pages?
Best regards
Joerg
Hi Olivia, thanks for update. The Themler is not listet at the programs and features in nthe control panel and so i cannot uninstall. However with your link it works so far ok. Thanks. An other question. Can I use the pictures from BillionDigital for my customer projects? Do they have to by a license too or is it covered with my account/licence. If so, I do have to menchend them on the website that they are from billiondigital or billionphotos? And what happend if my acount expired with the rights of the pictures in my clients pages? Best regards Joerg
Jörg Vierling
One thing is not working, if i want to run Themler in HTML5. It crashes by updating start again and again...
Jörg Vierling
Hi Olivia,
what is better:
to run themler from the desktop or install it on the server where the website is build?
What happen if there are updates or maintenance of the template and it functions? Does it go automatic, if Themler is installed on the server?
Best regards
Joerg from Berlin
Hi Olivia, what is better: to run themler from the desktop or install it on the server where the website is build? What happen if there are updates or maintenance of the template and it functions? Does it go automatic, if Themler is installed on the server? Best regards Joerg from Berlin
Jörg Vierling
Sorry, another question to the photos.
Can I use them only in Themler projects or can I use them in other Joomla Web projects?
Sorry, another question to the photos. Can I use them only in Themler projects or can I use them in other Joomla Web projects?
Support Team posted this 28 June 2017
Please refer to our FAQ page and let us know if you have any further questions regarding usage of the images:
http://answers.themler.com/articles/5545/billionphotos-faq
Themler desktop is a local webserver and CMS. There is no real difference. Themler works the same in Desktop application, own local or remote webserver.
When we release Themler update the option to update appears on the top bar in Themler. The update process can be started manually only. Usually it takes less than minute. In addition to this Themler creates a backup of the theme.
Hi, Please refer to our FAQ page and let us know if you have any further questions regarding usage of the images: http://answers.themler.com/articles/5545/billionphotos-faq > to run themler from the desktop or install it on the server where the website is build? Themler desktop is a local webserver and CMS. There is no real difference. Themler works the same in Desktop application, own local or remote webserver. When we release Themler update the option to update appears on the top bar in Themler. The update process can be started manually only. Usually it takes less than minute. In addition to this Themler creates a backup of the theme. Thank you, Olivia
Jörg Vierling
Jörg Vierling posted this 28 June 2017
Hi Olivia,
Thanks for the lines. I have to apologize because I do not know the English language. I have read the FAQ and have a question.
As a web designer with Themler I can create websites with pictures of BillionPhotos and sell them (the websites) to my commercial customers. Is that correct?
I only create websites for commercial customers. For me this is very important because of copyright law.
Best regards
from Berlin, Germany
Jörg
Hi Olivia, Thanks for the lines. I have to apologize because I do not know the English language. I have read the FAQ and have a question. **As a web designer with Themler I can create websites with pictures of BillionPhotos and sell them (the websites) to my commercial customers.** Is that correct? I only create websites for commercial customers. For me this is very important because of copyright law. Thanks Best regards from Berlin, Germany Jörg
Support Team posted this 29 June 2017
You are allowed sell the themes with images to individual customers.
But you are not allowed to resell themes (on theme stocks or on your website).
You do not need to specify the author (billiondigital) of the paid photos. But you should specify the author of the free photos (where you see appropriate note).
Hi, You are allowed sell the themes with images to individual customers. But you are not allowed to resell themes (on theme stocks or on your website). You do not need to specify the author (billiondigital) of the paid photos. But you should specify the author of the free photos (where you see appropriate note). Thank you, Olivia
Jörg Vierling
Jörg Vierling posted this 29 June 2017
Hi Olivia,
thanks so far. But still alow me to ask how that permission goes with the text of the "Terms of Use" of BillionDigital.com? There is a part in it:
Intellectual Property
Intellectual Property All materials (including the organization and presentation of such material) on this Website (the 'Content') are the property of Themler.com and may be protected by intellectual property laws including laws relating to copyrights, trade-marks, trade-names, internet domain names, and other similar rights.
The Content may only be used and copied for your own, non-commercial, personal or educational purposes, provided that the Content are not modified and that copyright and other intellectual property notices are not deleted.
You may not create derivative works from or otherwise exploit the Content in any way.
You see why I am a little bit concernd of your statement. You told me I can sell my website (made with Themler) including photos of BillionPhotos to my individuell customer as a website. Of course I do not sell themes as it self for other people they use them to build a website. But if I understand the "Terms of use" I can use the content (also photos) only for a personel and NON-COMMERCIAL purpose. But making a website for customers is a commercial act!
So I am a little bit uncertain of the legal things.
Please help me to understand!
Best regards
Dirk
Hi Olivia, thanks so far. But still alow me to ask how that permission goes with the text of the "Terms of Use" of BillionDigital.com? There is a part in it: --- **Intellectual Property** Intellectual Property All materials (including the organization and presentation of such material) on this Website (the 'Content') are the property of Themler.com and may be protected by intellectual property laws including laws relating to copyrights, trade-marks, trade-names, internet domain names, and other similar rights. **The Content may only be used and copied for your own, non-commercial, personal or educational purposes, provided that the Content are not modified and that copyright and other intellectual property notices are not deleted.** You may not create derivative works from or otherwise exploit the Content in any way. --- You see why I am a little bit concernd of your statement. You told me I can sell my website (made with Themler) including photos of BillionPhotos to my individuell customer as a website. Of course I do not sell themes as it self for other people they use them to build a website. But if I understand the "Terms of use" I can use the content (also photos) only for a personel and NON-COMMERCIAL purpose. But making a website for customers is a commercial act! So I am a little bit uncertain of the legal things. Please help me to understand! Best regards Dirk
As indicated on the Terms of use page, that article is related to themler.com and answers.themler.com. You can sell the theme to an individual customer with the images downloaded from billionphotos.com. All restrictions for the themes and photos are mostly related to reselling the template on some theme stocks.
Hi, As indicated on the Terms of use page, that article is related to themler.com and answers.themler.com. You can sell the theme to an individual customer with the images downloaded from billionphotos.com. All restrictions for the themes and photos are mostly related to reselling the template on some theme stocks. Sincerely, Hella
Jörg Vierling
friedrichdibbert560
friedrichdibbert560 posted this 20 October 2025
It sounds like a possible compatibility or cache issue might be causing the black screen. You could try clearing your browser cache or reinstalling the latest version to fix it. For those dealing with related data verification or case tracking, tools like Miami Dade arrest lookup can also be helpful in maintaining accurate records. Ensuring your system updates and plugins are current often resolves such software glitches effectively.
It sounds like a possible compatibility or cache issue might be causing the black screen. You could try clearing your browser cache or reinstalling the latest version to fix it. For those dealing with related data verification or case tracking, tools like [Miami Dade arrest lookup][1] can also be helpful in maintaining accurate records. Ensuring your system updates and plugins are current often resolves such software glitches effectively. [1]: https://miamidadecountycourt.com
