Delete on checkout Woocommerce
williamvanveen1988
williamvanveen1988 posted this 26 June 2017
Dear Support,
Is there a way to create delete button for into the checkout page to delete 1 product of the checkoutpage in Woocommerce checkout page
Kind regards,
William
Dear Support, Is there a way to create delete button for into the checkout page to delete 1 product of the checkoutpage in Woocommerce checkout page Kind regards, William
Support Team posted this 26 June 2017
You mean that you need the product to show on the checkout page (the second step in the purchase) that appears when you press the Proceed to Checkout button within the cart? We cannot edit it inside Themler. Products can be removed from the Cart view only.
Hi, You mean that you need the product to show on the checkout page (the second step in the purchase) that appears when you press the Proceed to Checkout button within the cart? We cannot edit it inside Themler. Products can be removed from the Cart view only. Sincerely, Hella
williamvanveen1988
Hey Hella,
This is a litle problem because the cart is not realy user friendly. The checkout is more userfriendly.
Some buttons is not translate (Woocommerce is dutch but he get the code out of the script of the theme)
The chechout button is not realy clear. Normal yoy have it on the end of the page but it is in the table.
Some people doesnt find the checkout button.
Here a demo of themler cart:
And now of a normal cart with standart theme:
How we can fix this?
Kind regards,
William
Hey Hella, This is a litle problem because the cart is not realy user friendly. The checkout is more userfriendly. Some buttons is not translate (Woocommerce is dutch but he get the code out of the script of the theme) The chechout button is not realy clear. Normal yoy have it on the end of the page but it is in the table. Some people doesnt find the checkout button. Here a demo of themler cart: !2017-06-26-11-06-24.jpg! And now of a normal cart with standart theme: !2017-06-26-11-10-05.jpg! How we can fix this? Kind regards, William
Unfortunately the position of the "Proceed to checkout" button cannot be changed. You can only try to find ерш button in the code of the generated theme and move it manually to the desired place. But each saving of the theme in Themler will erase custom changes.
The translations will be fixed in the future Themler updates.
Hi, Unfortunately the position of the "Proceed to checkout" button cannot be changed. You can only try to find ерш button in the code of the generated theme and move it manually to the desired place. But each saving of the theme in Themler will erase custom changes. The translations will be fixed in the future Themler updates. Thank you, Olivia
