image doesn't open in as image, opens as same product in new window
mptl.pharma
mptl.pharma posted this 29 June 2017
In magento, after installing themler theme, clicking on images opens a new window with product details page instead of opening image. From other answers I found it possibly could be lightbox issues. How to I enable lighbox in themler? where are relevant controls?
Support Team posted this 29 June 2017
Do you mean that Product Image on the Products template opens product details page instead of lightbox with product image?
This is behavior by default.
Hi, Do you mean that Product Image on the Products template opens product details page instead of lightbox with product image? This is behavior by default. Thank you, Olivia
mptl.pharma
mptl.pharma posted this 04 July 2017
yes - that's what I meant. Doesn't sound the best solution. How do it change it so images opens in lightbox or new window?
Support Team posted this 04 July 2017
You can try using CMS Code control instead of the product image. In this control you can add the code which outputs the product image and use any wrapper for lightbox or image. But it requires some skills.
Hi, You can try using CMS Code control instead of the product image. In this control you can add the code which outputs the product image and use any wrapper for lightbox or image. But it requires some skills. Thank you, Olivia
