Still Kunena problems with themler ...
einkauf4
einkauf4 posted this 04 July 2017
Hello guys,
the themler templates still make problems with kunena...
When will the themler work correct with kunena??
Hello guys, the themler templates still make problems with kunena... When will the themler work correct with kunena??
Support Team posted this 06 July 2017
We do not create themes for Kunena. If you have any display issues with the Kunena, then provide links to the problem pages, we'll try to provide the code to help.
It also may be because Kunena does not have the overrides for the styles that may come from any possible theme.
Hi, We do not create themes for Kunena. If you have any display issues with the Kunena, then provide links to the problem pages, we'll try to provide the code to help. It also may be because Kunena does not have the overrides for the styles that may come from any possible theme. Sincerely, Hella
