To go further on that question, if I put a section in the header containing a logo to the left and the hmenu to the right and activate the sticky for the entire section, is it possible to reduce the height of the menu as well as the size of the logo when you start to scroll down?
See an example of the researched result here: http://applead.rgenesis.com/demo/index-01.html
Note the transition easing too.
If it's feasible with Themler, can you please explain in detail how to achieve it?
Thanks in advance for the help! :)
