The theme name may contain only alphanumeric symbols and underscore (A-z, 0-9, '_').
colombimarco7
colombimarco7 posted this 06 July 2017
Buongiorno,
quando da wordpress cerco di fare edit in themler mi fa questo errore;
Please rename 'ciao/ciao' and 'ciao/ciao_preview' to the fitting name. Also you need to ensure that your name and 'Theme Name' in style.css are the same.
ma il template si chiama solo "ciao"
cosa posso fare?
grazie..
Buongiorno, quando da wordpress cerco di fare edit in themler mi fa questo errore; The theme name may contain only alphanumeric symbols and underscore (A-z, 0-9, '_'). Please rename 'ciao/ciao' and 'ciao/ciao_preview' to the fitting name. Also you need to ensure that your name and 'Theme Name' in style.css are the same. ma il template si chiama solo "ciao" cosa posso fare? grazie..
11 Comments
Support Team posted this 07 July 2017
Do you have theme installed on your host? In this case please check it via any FTP client, that the theme is installed at the location /path_to_wordpress/wp-content/themes/
where /path_to_wordpress/ is the location of your WordPress installation on the server. Make sure there is no extra subfolder with the same or similar name inside /themes. If there is some confusion, try to remove the previous theme, then re-export and install the theme by following this article:
http://answers.themler.com/articles/3624/how-to-install-wordpress-theme
Hello, Do you have theme installed on your host? In this case please check it via any FTP client, that the theme is installed at the location `/path_to_wordpress/wp-content/themes/` where `/path_to_wordpress/` is the location of your WordPress installation on the server. Make sure there is no extra subfolder with the same or similar name inside `/themes`. If there is some confusion, try to remove the previous theme, then re-export and install the theme by following this article: http://answers.themler.com/articles/3624/how-to-install-wordpress-theme Sincerely, Nettie, BillionDigital Team
colombimarco7
colombimarco7 posted this 07 July 2017
ok in effetti il tema era contenuto in un'altra cartella:
wp-content/themes/ciao/ciao
ma ora togliendo la cartella e facendo wp-content/themes/ciao funziona!
grazie..
ok in effetti il tema era contenuto in un'altra cartella: wp-content/themes/ciao/ciao ma ora togliendo la cartella e facendo wp-content/themes/ciao funziona! grazie..
Support Team posted this 10 July 2017
You're welcome.
Please let us know if you have any other questions/issues.
Themler Team
Hi, You're welcome. Please let us know if you have any other questions/issues. Thank you, Themler Team
k13487538
k13487538 posted this 05 October 2025
Ciao! The error you’re seeing happens because WordPress requires theme names to contain only alphanumeric characters and underscores. Even if your template is called “ciao,” it’s important to make sure the folder names and the Theme Name in style.css match exactly and follow the allowed format. So, renaming the folders to something like ciao_theme and updating the Theme Name accordingly should solve the problem. Also, double-check that there are no spaces or special characters in any of the theme files or folders. If you’re interested in exploring advanced customization options or managing root access for testing themes safely, you might want to check out magisk alpha zip, it offers powerful features that can help enhance your Android experience while experimenting with different apps.
Ciao! The error you’re seeing happens because WordPress requires theme names to contain only alphanumeric characters and underscores. Even if your template is called “ciao,” it’s important to make sure the folder names and the Theme Name in style.css match exactly and follow the allowed format. So, renaming the folders to something like ciao_theme and updating the Theme Name accordingly should solve the problem. Also, double-check that there are no spaces or special characters in any of the theme files or folders. If you’re interested in exploring advanced customization options or managing root access for testing themes safely, you might want to check out [magisk alpha zip][1], it offers powerful features that can help enhance your Android experience while experimenting with different apps. [1]: https://magiskapp.pro/magisk-alpha/
Abbas Khan
Abbas Khan posted this 17 February 2026
FunnyNamesPro also shines because funny names are easier to remember and share with others. When someone hears a humorous or clever name, it sticks in their mind longer than a plain one. Laughter creates connection, and connection creates memory. This simple truth makes funny Blooket Names powerful in everyday life.
FunnyNamesPro also shines because funny names are easier to remember and share with others. When someone hears a humorous or clever name, it sticks in their mind longer than a plain one. Laughter creates connection, and connection creates memory. This simple truth makes funny **[Blooket Names][1]** powerful in everyday life. [1]: https://funnynamespro.com/funny-blooket-names/
Abbas Khan
Visitors can come in for a quick laugh or stay longer to explore many options. The experience feels light, friendly, and welcoming from start to finish. In a digital world filled with noise and pressure, a space dedicated to humor and creativity feels refreshing sourdough starter names. People appreciate places that allow them to relax and enjoy small moments of fun.
Visitors can come in for a quick laugh or stay longer to explore many options. The experience feels light, friendly, and welcoming from start to finish. In a digital world filled with noise and pressure, a space dedicated to humor and creativity feels refreshing **[sourdough starter names][1]**. People appreciate places that allow them to relax and enjoy small moments of fun. [1]: https://profunnynames.com/funny-sourdough-starter-names/
jesonlee90900
jesonlee90900 posted this 02 March 2026
Blooket Join refers to the quick and simple process of entering a live Blooket game using a unique code generated by the host.
[Blooket Join][1] refers to the quick and simple process of entering a live Blooket game using a unique code generated by the host. [1]: https://bloketjoin.com/
ahmadalyhamza
ahmadalyhamza posted this 03 March 2026
The error you are seeing in Themler is usually caused by a mismatch between the theme's folder name and the "Theme Name" declared in your style.css file. WordPress requires these names to be identical and strictly follow the alphanumeric and underscore (_) rule; even a single space or a slash (/) will trigger this validation error. To fix this, rename your theme folder via FTP or File Manager and ensure the header in your style.css matches that exact name without any special characters. While troubleshooting these technical WordPress issues, if you're looking for the latest mobile rewards and daily updates in Pakistan, you can visit this website for more information.
The error you are seeing in Themler is usually caused by a mismatch between the theme's folder name and the "Theme Name" declared in your style.css file. WordPress requires these names to be identical and strictly follow the alphanumeric and underscore (_) rule; even a single space or a slash (/) will trigger this validation error. To fix this, rename your theme folder via FTP or File Manager and ensure the header in your style.css matches that exact name without any special characters. While troubleshooting these technical WordPress issues, if you're looking for the latest mobile rewards and daily updates in Pakistan, you can visit [this website][1] for more information. [1]: https://telenrquiztoday.pk/
ahmadalyhamza
ahmadalyhamza posted this 07 April 2026
Themler errors are usually caused by a mismatch between the theme's folder name and the name in your style.css. WordPress requires these to be identical and strictly alphanumeric (using underscores instead of spaces or slashes). To fix it, simply rename your folder and update the CSS header to match exactly.
While you're fixing your site, you can stay updated with the latest mobile rewards at telenor quiz for quick and accurate daily answers.
Themler errors are usually caused by a mismatch between the theme's folder name and the name in your style.css. WordPress requires these to be identical and strictly alphanumeric (using underscores instead of spaces or slashes). To fix it, simply rename your folder and update the CSS header to match exactly. While you're fixing your site, you can stay updated with the latest mobile rewards at [telenor quiz][1] for quick and accurate daily answers. [1]: https://mytelnoranswertoday.pk/
mikelweller3
mikelweller3 posted this 4 weeks ago
Buongiorno
Questo errore di solito compare quando il nome della cartella del tema contiene caratteri non validi o una struttura non corretta. Anche se vedi “ciao”, probabilmente dentro /wp-content/themes/ hai una cartella tipo ciao/ciao oppure con qualche simbolo non supportato.
Prova questi passaggi:
Vai in /wp-content/themes/ e assicurati che il nome sia solo ciao (senza sottocartelle duplicate)
Controlla il file style.css e verifica che il campo Theme Name sia esattamente uguale
Evita slash o caratteri speciali, usa solo lettere, numeri o underscore
Dopo aver corretto, riattiva il tema da WordPress.
Se ti serve, puoi anche controllare qui per guide e aggiornamenti utili: http://telequiz.pk/
Buongiorno Questo errore di solito compare quando il nome della cartella del tema contiene caratteri non validi o una struttura non corretta. Anche se vedi “ciao”, probabilmente dentro /wp-content/themes/ hai una cartella tipo ciao/ciao oppure con qualche simbolo non supportato. Prova questi passaggi: Vai in /wp-content/themes/ e assicurati che il nome sia solo ciao (senza sottocartelle duplicate) Controlla il file style.css e verifica che il campo Theme Name sia esattamente uguale Evita slash o caratteri speciali, usa solo lettere, numeri o underscore Dopo aver corretto, riattiva il tema da WordPress. Se ti serve, puoi anche controllare qui per guide e aggiornamenti utili: [http://telequiz.pk/][1] [1]: http://telequiz.pk/
therobertscott56
therobertscott56 posted this 3 weeks ago
The error you are seeing in Themler is usually caused by a mismatch between the theme's folder name and the "Theme Name" declared in your style.css file. WordPress requires these names to be identical and strictly follow the alphanumeric and underscore (_) rule; even a single space or a slash (/) will trigger this validation error. To fix this, rename your theme folder via FTP or File Manager and ensure the header in your style.css https://telenorquiztodays.pk/ matches that exact name without any special characters. While troubleshooting these technical WordPress issues, if you're looking for the latest mobile rewards and daily updates in Pakistan, you can visit this website for more information.
