I can't export theme zip in themler mac for joomla.
hossien_badawood
hossien_badawood posted this 08 July 2017
when I finish from developing the theme for joomla I can't export it to my desktop I tried to fix this problem by uninstalling Themler for Mac then reinstall it but it stell cant export
Support Team posted this 10 July 2017
Could you please start Themler from browser using the following link
http://127.0.0.1:29958/themler_4089206109/joomla/administrator
and try to export. Does the issue continue?
Hi, Could you please start Themler from browser using the following link http://127.0.0.1:29958/themler_4089206109/joomla/administrator and try to export. Does the issue continue? Thank you, Olivia
uwe262
uwe262 posted this 12 December 2018
I also have the problem and the link is not working
Support Team posted this 12 December 2018
The numbers themler_4089206109 in the link are individual for each installation. To see exact numbers, please open Live Preview in Themler.
As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website.
Hello, The numbers `themler_4089206109` in the link are individual for each installation. To see exact numbers, please open Live Preview in Themler. As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type `~/Library` and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website. Sincerely, Nettie
