I have updated my site to Wordpress 4.8 and WooCommerce plugin to version 3.1.0.
In the WooCommerce system status I can see the following message for file cart.php:
version 3.0.0 is out of date. The core version is 3.1.0 and the problem is that the cart
is not shown correctly in mobile phone.
I tried to change the comment in the cart.php file - from 3.0.0 to 3.1.0. I have read about this in the forum.
Nothing changed.
Then I replaced the code in cart.php with the 3.1.0 code version (which I copied from another file),
Now I could see the cart correctly.
What is the solution to this problem? Is there a themler update so that it supports wordpress 4.8 and
woocommerce 3.1.0 correctly?
Hello I have updated my site to Wordpress 4.8 and WooCommerce plugin to version 3.1.0. In the WooCommerce system status I can see the following message for file **cart.php**: **version 3.0.0 is out of date. The core version is 3.1.0** and the problem is that the cart is not shown correctly in mobile phone. I tried to change the comment in the cart.php file - from 3.0.0 to 3.1.0. I have read about this in the forum. Nothing changed. Then I replaced the code in cart.php with the 3.1.0 code version (which I copied from another file), Now I could see the cart correctly. What is the solution to this problem? Is there a themler update so that it supports wordpress 4.8 and woocommerce 3.1.0 correctly? Thank you
