Sites without header
david.nagel.dsc
david.nagel.dsc posted this 15 July 2017
Hello, the header is always for all templates but is there a way to have two pages without the header?
Thanks a lot! :)
Hello, the header is always for all templates but is there a way to have two pages without the header? Thanks a lot! :)
Support Team posted this 17 July 2017
You can disable header on the specific templates under the Insert tab. But it works for all pages which use this template. Unfortunately you cannot disable header on certain pages but you can disable Header on all pages and use content container which looks like header on the pages where you need it. If you copy and paste the container as link it will share its style between all its copies:
Hi, You can disable header on the specific templates under the Insert tab. But it works for all pages which use this template. Unfortunately you cannot disable header on certain pages but you can disable Header on all pages and use content container which looks like header on the pages where you need it. If you copy and paste the container as link it will share its style between all its copies: !paste-link.png! Thank you, Olivia
