How do i change the image preview of the page when is shared on facebook?
danko.brzovic
danko.brzovic posted this 24 July 2017
I added an image of whatsapp on the header of my page, and now when i share the page on facebook, the image that appears is the whatsapp one instead of the page logo.
How do i change that? i think it has something to do with the metadata of the header but i dont know what to do.
Hello, I added an image of whatsapp on the header of my page, and now when i share the page on facebook, the image that appears is the whatsapp one instead of the page logo. How do i change that? i think it has something to do with the metadata of the header but i dont know what to do.
14 Comments
gcg
gcg posted this 24 July 2017
Hi Danko,
This issue is not related with Themler. To solve it you just have to add in your code header the Open Graph metatags. If you don't use this OG tags, then Facebook (and the others socials media) are going to take a random image from your site, in your case, the whatsapp image.
More details here > https://davidwalsh.name/facebook-meta-tags
Sample > https://davidwalsh.name/demo/facebook-metas.php
Or, if you use any CMS like Joomla or Wordpress, you just to search in Google any plugin/widget to add that from the backend.
Hi Danko, This issue is not related with Themler. To solve it you just have to add in your code header the Open Graph metatags. If you don't use this OG tags, then Facebook (and the others socials media) are going to take a random image from your site, in your case, the whatsapp image. More details here > https://davidwalsh.name/facebook-meta-tags Sample > https://davidwalsh.name/demo/facebook-metas.php Or, if you use any CMS like Joomla or Wordpress, you just to search in Google any plugin/widget to add that from the backend. Regards
danko.brzovic
Hi Danko,
Great thank you!
But can i directly write these metadata codes on themler? in the "aditional head html" setting..? instead of searching for third party plugin/widget
> Hi Danko, > > This issue is not related with Themler. To solve it you just have to add in your code header the Open Graph metatags. If you don't use this OG tags, then Facebook (and the others socials media) are going to take a random image from your site, in your case, the whatsapp image. > > More details here > https://davidwalsh.name/facebook-meta-tags > Sample > https://davidwalsh.name/demo/facebook-metas.php > > Or, if you use any CMS like Joomla or Wordpress, you just to search in Google any plugin/widget to add that from the backend. > > Regards Great thank you! But can i directly write these metadata codes on themler? in the "aditional head html" setting..? instead of searching for third party plugin/widget
Support Team posted this 25 July 2017
Yes, you can add meta tags under the Home >> Settings >> Additional HEAD HTML. The code will be added directly into the <head> tag.
Hi, Yes, you can add meta tags under the Home >> Settings >> Additional HEAD HTML. The code will be added directly into the `<head>` tag. Sincerely, Hella
danko.brzovic
danko.brzovic posted this 25 July 2017
Yes, you can add meta tags under the Home >> Settings >> Additional HEAD HTML. The code will be added directly into the &lt;head&gt; tag.
> Sincerely,
> Hella
Awesome, thanks.
So, is this the correct format to write metatags on the "Additional HEAD HTML" setting?--> "<meta property content>"
> Hi, > > Yes, you can add meta tags under the Home >> Settings >> Additional HEAD HTML. The code will be added directly into the `&lt;head&gt;` tag. &gt; &gt; Sincerely, &gt; Hella Awesome, thanks. So, is this the correct format to write metatags on the &quot;Additional HEAD HTML&quot; setting?--&gt; &quot;&lt;meta property content&gt;&quot;
Support Team posted this 26 July 2017
Yes, you can take tags right from this link and insert them under the Home >> Settings >> Additional HEAD HTML with your own images links:
Hi, Yes, you can take tags right from this link and insert them under the Home >> Settings >> Additional HEAD HTML with your own images links: https://davidwalsh.name/demo/facebook-metas.php Sincerely, Hella
danko.brzovic
danko.brzovic posted this 27 July 2017
Thank you!
> Hi, > > Yes, you can take tags right from this link and insert them under the Home >> Settings >> Additional HEAD HTML with your own images links: > https://davidwalsh.name/demo/facebook-metas.php > > Sincerely, > Hella Thank you!
Support Team posted this 27 July 2017
You are welcome. Let us know if you need our further help.
You are welcome. Let us know if you need our further help. Sincerely, Hella
danko.brzovic
Hella, so i was able to do what i wanted. Or at least for the homepage. How can i add different metatags for the articles??
> You are welcome. Let us know if you need our further help. > > Sincerely, > Hella Hella, so i was able to do what i wanted. Or at least for the homepage. How can i add different metatags for the articles??
Support Team posted this 28 July 2017
If using CMS, there is no possibility to add different meta tags for each page.
Maybe you indeed will need some plug-in for your CMS.
Hi, If using CMS, there is no possibility to add different meta tags for each page. Maybe you indeed will need some plug-in for your CMS. Sincerely, Hella
danko.brzovic
danko.brzovic posted this 28 July 2017
okay... and do you know if maybe i can directly right some code on each page? the way i see it, it should be possible to work with joomla and personalized code on a page at the same time right?
> Hi, > > If using CMS, there is no possibility to add different meta tags for each page. > Maybe you indeed will need some plug-in for your CMS. > > Sincerely, > Hella okay... and do you know if maybe i can directly right some code on each page? the way i see it, it should be possible to work with joomla and personalized code on a page at the same time right?
danko.brzovic
nevermind, i already found the plugin jajajaja. though i have a lot of questions, since i'm kind of new to joomla and themler, i don't want to keep bothering you. Is there any manuall i can read so that i can learn how to fully use them?
> > Hi, > > > > If using CMS, there is no possibility to add different meta tags for each page. > > Maybe you indeed will need some plug-in for your CMS. > > > > Sincerely, > > Hella > > okay... and do you know if maybe i can directly right some code on each page? the way i see it, it should be possible to work with joomla and personalized code on a page at the same time right? nevermind, i already found the plugin jajajaja. though i have a lot of questions, since i'm kind of new to joomla and themler, i don't want to keep bothering you. Is there any manuall i can read so that i can learn how to fully use them?
Support Team posted this 30 July 2017
Our support service is free and available for all customers.
Therefore please feel free to contact us if you have any specific questions.
We have some joomla and general manuals here
http://answers.themler.com/Doc
But you can contact us if you have any questions. We're always happy to help our customers.
Hi, Our support service is free and available for all customers. Therefore please feel free to contact us if you have any specific questions. We have some joomla and general manuals here http://answers.themler.com/Doc But you can contact us if you have any questions. We're always happy to help our customers. Thank you, Olivia
info3272
info3272 posted this 19 November 2017
> Hi, > > Our support service is free and available for all customers. > Therefore please feel free to contact us if you have any specific questions. > > We have some joomla and general manuals here > http://answers.themler.com/Doc > > But you can contact us if you have any questions. We're always happy to help our customers. > > Thank you, > Olivia Thanks ---------
Maria desuja
Maria desuja posted this 6 days ago
Use these steps:
  1. Click right-click inside the "update status" box at the top of the Facebook wall.
  2. Select "Paste" from the context menu.
  3. Your link is entered into the status box and the Facebook system automatically scans for a thumbnail image.
Use these steps: 1. Click right-click inside the "update status" box at the top of the Facebook wall. 2. Select "Paste" from the context menu. 3. Your link is entered into the status box and the Facebook system automatically scans for a thumbnail image.
