Main Horizontal Navigation doubles in mobile view when adding search to block
nmcfadden
nmcfadden posted this 27 July 2017
I am using Drupal 7 and I have modified the default theme that opens when you select Drupal. I have added the drupal "search" to the top main navigation which works fine, however, when you switch to mobile view I receive a double drop down menu that seems to operate as one menu.
How do I get rid of the double look? (SEE SCREEN SHOTS)
I am using Drupal 7 and I have modified the default theme that opens when you select Drupal. I have added the drupal "search" to the top main navigation which works fine, however, when you switch to mobile view I receive a double drop down menu that seems to operate as one menu. How do I get rid of the double look? (SEE SCREEN SHOTS)
Support Team posted this 27 July 2017
Please attach the exported theme (exported with the editor included) so we could review the settings.
Hi, Please attach the exported theme (exported with the editor included) so we could review the settings. Sincerely, Hella
nmcfadden
I have attached the exported file as requested.
Support Team posted this 28 July 2017
Where exactly you added search block? The region for Horizontal menu is not a regular region. If you added search into this region the issue is quite possible because theme wraps the block in this region into Themler Horizontal menu.
If you need a region in this position we suggest that you use Columns control with menu in left column and Drupal Region control in the right column. Or you can try to build the the whole Header using Columns.
Hi, Where exactly you added search block? The region for Horizontal menu is not a regular region. If you added search into this region the issue is quite possible because theme wraps the block in this region into Themler Horizontal menu. If you need a region in this position we suggest that you use Columns control with menu in left column and Drupal Region control in the right column. Or you can try to build the the whole Header using Columns. Please keep us posted about the progress. Thank you, Olivia
nmcfadden
nmcfadden posted this 17 August 2017
I believe you are correct. I decide to rebuild the entire header and I was able to resolve the issue. I used a header template that had the correct regions already built in.
Although I did not complete this using your method, I believe your method would have worked.
I believe you are correct. I decide to rebuild the entire header and I was able to resolve the issue. I used a header template that had the correct regions already built in. Although I did not complete this using your method, I believe your method would have worked.
Support Team posted this 21 August 2017
Nice to hear that you have also found the solution. Feel free to contact us in any other occasion.
Hi, Nice to hear that you have also found the solution. Feel free to contact us in any other occasion. Sincerely, Hella
