I can not use Themler because I have this message:
Error in database connection
What can I Do?
I can not use Themler because I have this message: Error in database connection What can I Do?
What can I Do?
I can not use Themler because I have this message: Error in database connection What can I Do?Hello,
Please try temporarily disabling antivirus and firewall and run Themer anew. If the issue is still present, please try the following:
