Possibility of editing pages oif template not made with themler
maillard.jul
maillard.jul posted this 02 August 2017
Is it possible to use Themler as a page Creator instead of Joomla articles if the theme is not made with themler ?
If yes, how ?
Thanks in advance
Julien
Hello, Is it possible to use Themler as a page Creator instead of Joomla articles if the theme is not made with themler ? If yes, how ? Thanks in advance Julien
Support Team posted this 03 August 2017
Themler is a theme generator tool. It does not create CMS content. In joomla or WordPress you can edit the content of the existing CMS articles. Themler can edit the content of the native joomla or WordPress content types only.
But please note that if the content was not created in Themler it will be rendered in Themler as HTML control. We made content editor feature to add Themler content to empty CMS articles mostly, not for editing existing content. It can be done without Themler easily.
Hi, Themler is a theme generator tool. It does not create CMS content. In joomla or WordPress you can edit the content of the **existing** CMS articles. Themler can edit the content of the native joomla or WordPress content types only. But please note that if the content was not created in Themler it will be rendered in Themler as HTML control. We made content editor feature to add Themler content to empty CMS articles mostly, not for editing existing content. It can be done without Themler easily. Thank you, Olivia
maillard.jul
maillard.jul posted this 03 August 2017
Thanks.
Not sure i understand...
If my template/theme is not made with themler.. can i add content , like a page with themler ?
Julien
Thanks. Not sure i understand... If my template/theme is not made with themler.. can i add content , like a page with themler ? Thanks Julien
Support Team posted this 04 August 2017
The content and theme are two different and independent objects in joomla.
Themler is a theme generator tool, not a content builder.
But if you're working on Themler theme in Themler you can also edit the content of the existing joomla articles. But Themler does not recognize joomla content created outside of Themler as Themler controls. Therefore you will see this content in Themler as HTML control and you will be able edit it as HTML only.
Themler content editor feature is created to add Themler controls (as shortcodes) to joomla article content. Such controls can be edited in Themler visual builder.
Themler does not create joomla articles, pages or modules. This is theme generator tool.
We offer Themler Demo mode which has all Themler features except saving and exporting. You can install Themler theme on your local or remote joomla and see how Themler works.
Hi, The content and theme are two different and independent objects in joomla. Themler is a theme generator tool, not a content builder. But if you're working on Themler theme in Themler you can also edit the content of the existing joomla articles. But Themler does not recognize joomla content created outside of Themler as Themler controls. Therefore you will see this content in Themler as HTML control and you will be able edit it as HTML only. Themler content editor feature is created to add Themler controls (as shortcodes) to joomla article content. Such controls can be edited in Themler visual builder. Themler does not create joomla articles, pages or modules. This is theme generator tool. We offer Themler Demo mode which has all Themler features except saving and exporting. You can install Themler theme on your local or remote joomla and see how Themler works. Thank you, Olivia
