I would like to use images in menu (instead of text) on all devices except mobiles and on mobiles i would like to be displayed only text (without image).
How i can do it?
How i can do it?
As I understand you want to use specific images instead of text on menu items. This is a part of the content. But Themler is a theme generator tool and does not allow to set unique images for menu items. You can do it in Joomla. But in this way you will not be able to changes them to text in responsive mode. You you can try using two different menus: one with images and one with text for responsive mode.
You understand well. There is a possibility to define it in theme. Look at site babell.com.pl - first position in hmenu. This theme is not generated in themler, but im curious if it is possible.
You mean to set the different color of one word in the menu item? That is not possible in Themler, the color is specified for the whole menu item text. You can use an image for it as Olivia explained above.That should be done in your CMS admin panel, it is not possible to add inside Themler.
No, the text "PRZEJDŹ DO E-SKLEPU" it is image, not title of menu. This image is invisible on phones, ther is only title of menu "e-sklep"
Menu change too many times and it has too many position to edit it and create every time 2 version (for computer and for phones view)
No, the text "PRZEJDŹ DO E-SKLEPU" it is image, not title of menu. This image is invisible on phones, ther is only title of menu "e-sklep" Menu change too many times and it has too many position to edit it and create every time 2 version (for computer and for phones view)Last edited 03 August 2017 by rocherka
Olivia explained that you can create two menus. One that will be visible on the phone view and the other one that will be present on all other screen views. The one menu will be normal with the text links and in the other one you can insert the image. But once again, inserting the image in the menu item is possible in the CMS admin only.
I know that image i can insert in admin panel.
Unfortunately Themler theme does not have specific control or control setting responsible for image. Therefore there is no option to hide the text in desktop mode and show it in responsive mode.
If you know css you can add custom css which will do it.
