Testing how to edit themes in Prestashop for first time, so it is maybe something trivial I am missing.
Installed theme by manual. All settings in backend are as on screenshots.
Only difference is cannot use "www" in URL because it is a localhost.
And cannot edit theme. Theme is default theme downloaded from themler.com.
Outline tab is empty, cannot click on anything. Dont see any special JS errors. Layout button not working.
Only thing I can do is to resize sheet, but still not even this holds.
Short said edit screen behaves as real website.
Get this error, but did not help to disable this module:
Testing how to edit themes in Prestashop for first time, so it is maybe something trivial I am missing. Installed theme by manual. All settings in backend are as on screenshots. Only difference is cannot use "www" in URL because it is a localhost. And cannot edit theme. Theme is default theme downloaded from themler.com. Outline tab is empty, cannot click on anything. Dont see any special JS errors. Layout button not working. Only thing I can do is to resize sheet, but still not even this holds. Short said edit screen behaves as real website. Get this error, but did not help to disable this module: > Timestamp: 6/21/2015 11:56:14 Error: TypeError: domIdProduct is > undefined Source File: > http://localhost/my-prestashop/themes/Untitled/js/modules/blockcart/ajax-cart.js > Line: 257Timestamp: 6/21/2015 11:56:14 Error: TypeError: domIdProduct is
Line: 257
