Hotspots
freds1959
freds1959 posted this 14 August 2017
Hello Themler,
Can you inform me or you have an hotspot possibility? because I want on a image more hyperlinks, is that possible?
Kind regards,
Fred
Hello Themler, Can you inform me or you have an hotspot possibility? because I want on a image more hyperlinks, is that possible? Kind regards, Fred
10 Comments
Support Team posted this 14 August 2017
You can try to position containers with the absolute positioning above the image in the desired spot and then insert a link in that container. But it will be easier to use some image map plug-in for your CMS.
Hi, You can try to position containers with the absolute positioning above the image in the desired spot and then insert a link in that container. But it will be easier to use some image map plug-in for your CMS. Sincerely, Hella
freds1959
Hello Hella I want the website build in HTML so, and for example I send a image so that you can see what I mean.
Fred
Hello Hella I want the website build in HTML so, and for example I send a image so that you can see what I mean. Regards, Fred
So looks like you need such menu with the items with the different color? You can add the container control and then insert there 5 images of the separate part that should have a link. Set them all to float left and for each image you can specify the desired link.
Hi, So looks like you need such menu with the items with the different color? You can add the container control and then insert there 5 images of the separate part that should have a link. Set them all to float left and for each image you can specify the desired link. Sincerely, Hella
freds1959
freds1959 posted this 15 August 2017
Thanks Hella,
It works but I searching for one thing, when you see the snapshot then you can see that between the buttons to many space is and I am woundering how I can that space make smaller?
Fred
Thanks Hella, It works but I searching for one thing, when you see the snapshot then you can see that between the buttons to many space is and I am woundering how I can that space make smaller? Sincerely, Fred
Support Team posted this 15 August 2017
I assume that you have set the menu align to be justified, try to set it to center, that should solve the issue. In case it does not help, please attach the theme exported with the editor included.
Hi, I assume that you have set the menu align to be justified, try to set it to center, that should solve the issue. In case it does not help, please attach the theme exported with the editor included. Sincerely, Hella
Malinka
Malinka posted this 15 August 2017
Test an online imagemap generator like this maybe:
http://imagemap-generator.dariodomi.de/
Best regards
Malinka
Hi Test an online imagemap generator like this maybe: http://imagemap-generator.dariodomi.de/ Best regards Malinka
freds1959
freds1959 posted this 16 August 2017
Hi Hella,
I've tried it but I can not manage it? so maybe jou can find it, I send the theme export.
Fred
Hi Hella, I've tried it but I can not manage it? so maybe jou can find it, I send the theme export. Sincerely, Fred
Support Team posted this 16 August 2017
There was no float left option set to all the images. And also there was a margin coming from the Home >> Settings >> Margin. Have a look to the attached theme.
Sincerely.
Hi, There was no float `left` option set to all the images. And also there was a margin coming from the Home >> Settings >> Margin. Have a look to the attached theme. Sincerely. Hella
freds1959
freds1959 posted this 17 August 2017
Thanks Hella,
For now itś okay, I want to try to make some space between the buttons, something of 2 pixels, when I managed It I let you know.
Fred
Thanks Hella, For now itś okay, I want to try to make some space between the buttons, something of 2 pixels, when I managed It I let you know. Sincerely, Fred
Support Team posted this 17 August 2017
You are welcome. Let us know when you need our further help.
You are welcome. Let us know when you need our further help. Sincerely, Hella
