posted this
31 August 2017
Maybe you mean that the content of the theme is not imported inside the site. Let me explain a bit. When you create the theme inside Themler, there are areas marked with different colors: orange, blue and green. Orange areas are shared through the whole theme and the content you place in them will be seen on all the pages. That is Header, Footer, Sidebars areas. The blue area is the part of the concrete template. When you add control into the blue area of the Page template, that control will appear on all the pages of your site that do use the Page template. And the green is a content area. The content placed there is the post or page dynamic content that you usually add inside the WP admin. So to see the green area content on the site, you need to import the content from the file:
http://answers.themler.io/articles/72522/import-export-content
Please let me know if you need our further help.
Maybe you mean that the content of the theme is not imported inside the site. Let me explain a bit. When you create the theme inside Themler, there are areas marked with different colors: orange, blue and green. *Orange* areas are shared through the whole theme and the content you place in them will be seen on all the pages. That is Header, Footer, Sidebars areas. The *blue* area is the part of the concrete template. When you add control into the blue area of the Page template, that control will appear on all the pages of your site that do use the Page template. And the *green* is a content area. The content placed there is the post or page dynamic content that you usually add inside the WP admin. So to see the green area content on the site, you need to import the content from the file:
