Get accordion to work
johansantamaria
johansantamaria posted this 31 August 2017
Hi Support team.
I created an HTML Website with themler to get the accordion working.
I attached my theme to this ticket.
If you open the Homepage, you see 2 accordions. (that I created based on the bootstrap-code)
The one on the top is an example that I picked somewhere.
The one on the bottom is the one that I changed to have the exact layout as the accordion that I have in the design-tab in themler.
Almost everything is working, except for 2 things:
1. In the design-tab, for the accordion-control: I've set the background of the active item to orange, but it doesn't reflect to my accordion on the homepage. Can you tell me what is wrong in my html-control? Probably it's something simple, but I don't see the solution.
The goal is to have the exact same design of the accordion in the homepage as the accordion on the design tab (in themler).
  1. For the accordion in the bottom of the homepage, I also want the same behaviour as the accordion on the top of the homepage --> so that only 1 item is active and display it's content. (and that all other items of the accordion are collapsed) --> so that it behaves like an accordion.
Can you change my html-code to get it working? And explain me chick changes you did? (and why).
Many thanks!
Kind Regards,
Johan
Hi Support team. I created an HTML Website with themler to get the accordion working. I attached my theme to this ticket. If you open the Homepage, you see 2 accordions. (that I created based on the bootstrap-code) The one on the top is an example that I picked somewhere. The one on the bottom is the one that I changed to have the exact layout as the accordion that I have in the design-tab in themler. Almost everything is working, except for 2 things: 1. In the design-tab, for the accordion-control: I've set the background of the active item to orange, but it doesn't reflect to my accordion on the homepage. Can you tell me what is wrong in my html-control? Probably it's something simple, but I don't see the solution. The goal is to have the exact same design of the accordion in the homepage as the accordion on the design tab (in themler). 2. For the accordion in the bottom of the homepage, I also want the same behaviour as the accordion on the top of the homepage --> so that only 1 item is active and display it's content. (and that all other items of the accordion are collapsed) --> so that it behaves like an accordion. Can you change my html-code to get it working? And explain me chick changes you did? (and why). Many thanks! Kind Regards, Johan
Support Team posted this 04 September 2017
Sorry for the delay. Please try bootstrap example which is available here:
https://getbootstrap.com/docs/3.3/javascript/#collapse
The native bootstrap accordion works just fine.
Unfortunately we do not provide support for custom code. We can check it only if it works with the Themler theme in a different way than with any other theme. I suggest that you create your accordion basing on the bootstrap example I provided.
Hi, Sorry for the delay. Please try bootstrap example which is available here: https://getbootstrap.com/docs/3.3/javascript/#collapse The native bootstrap accordion works just fine. Unfortunately we do not provide support for custom code. We can check it only if it works with the Themler theme in a different way than with any other theme. I suggest that you create your accordion basing on the bootstrap example I provided. Thank you, Olivia
nadiko8966
nadiko8966 posted this 02 April 2026
Poki games offer a seamless gaming experience with a focus on simplicity and enjoyment. The platform is perfect for anyone who wants to play high-quality games without any barriers.
[Poki games][1] offer a seamless gaming experience with a focus on simplicity and enjoyment. The platform is perfect for anyone who wants to play high-quality games without any barriers. [1]: https://pokigames.co/
luizdavid77111
luizdavid77111 posted this 4 weeks ago
Discover the joy of play with Bluey toys online, where creativity, adventure, and laughter come together for kids of all ages. Our collection of Bluey toys for 3 year olds is designed to inspire imagination, encourage learning, and create fun-filled moments every day. From playful characters to exciting activities, Bluey Toys brings happiness and entertainment to every child’s world.
Discover the joy of play with Bluey toys online, where creativity, adventure, and laughter come together for kids of all ages. Our collection of [Bluey toys for 3 year olds][1] is designed to inspire imagination, encourage learning, and create fun-filled moments every day. From playful characters to exciting activities, Bluey Toys brings happiness and entertainment to every child’s world. [1]: https://blueytoys.com/bluey-toys-for-3-year-olds/
