i got a problem when i open themler trying to create joomla template
problem screenshot attach...
Could you please try to rename the following folder into joomla-old and try to run Themler once again:
C:\ProgramData\Themler\hd_data\themler_2470264438\joomla
If it runs successfully, then find your theme in the old folder, zip-compress it and import in Themler.
Sicnerely,
i deleted everything even my saved thems and now it works.
different question..
can i import a themler template that i export to HTML and import as joomla?
and how can i import artisteer template to themler?
Unfortunately, it is not possible, to convert Themler HTML theme to Joomla because of a different theme structure.
Relating Artisteer - it is possible to export themes for Themler for Joomla, Wordpress and HTML with this version:
i did what you said and this is what i got (attach)
i did what you said and this is what i got (attach)Hello,
Please make sure you have selected namely "Themler for Joomla" option in Artisteer export dialog, not just Joomla.
i have only one option named just "themler"
i have only one option named just "themler"Hello,
Right, but in the export dialog there is also an option to select CMS for Themler - select Joomla there:
yes now i see it - thank you very much for the help!
yes now i see it - thank you very much for the help!You are welcome! Please feel free to contact us in any other case.
