How can I remove zebra style from tables in themler for a wordpress theme?
How can I remove ***zebra style*** from tables in themler for a **wordpress** theme?
How can I remove ***zebra style*** from tables in themler for a **wordpress** theme?Hello,
Please try editing the Alternate Row style for Table in Styles, and make it the same as default row style.
Thanks Nettie,
This is what I was looking for.
Best regards,
Mark Jansen
I have the same problem but editing the Alternate Row background color does not change the color when I use the template. The example in themler does show the change. I have tried edited the template.css directly by searching for "odd" and editing the color and still does not work.
Any help would be appreciated
Sorry should have added I am using Joomla
I have the same problem but editing the Alternate Row background color does not change the color when I use the template. The example in themler does show the change. I have tried edited the template.css directly by searching for "odd" and editing the color and still does not work. Any help would be appreciated Sorry should have added I am using JoomlaLast edited 21 February 2018 by peterc
Please provide a link to the page with the issue. Or better create a private topic with the access to your site back end so we could also check the theme settings.
