i want test Themler on Windows 10 DEsktop.
When i start it the diagnostic Tool shows me one Error:
ERROR:MySQL service isn't installed
What must i do to get Themler started?
Can help anyone please?
Best Regards
Here is the complete Log File Text:
Please wait...Themler Diagnostics Log
Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket.
INFO:Version files finded:
INFO: C:\PROGRA~3\Themler\1.0.319.25.ver
INFO:Check free disk space...
INFO:Check Services...
INFO:Check Files...
INFO:Check HTTP Server...
INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_1437116519
INFO: Check is url available: http://localhost:12080/themler_1437116519/startup
INFO:Check INI Files...
INFO:No errors!
======== Content of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
Program files detected C:\Program Files (x86)
Must be on program files\themler\bin
Datentr�ger in Laufwerk C: ist localhost
Volumeseriennummer: D4D0-1415
Verzeichnis von C:\Program Files (x86)\Themler\bin
24.09.2017 05:49 <dir> .
24.09.2017 05:49 <dir> ..
24.09.2017 05:49 <dir> 7zip
24.09.2017 05:49 <dir> apache
24.09.2017 05:49 <dir> diagnostics
22.06.2016 14:18 1.402 install-apache.bat
22.06.2016 14:18 2.724 install-mysql.bat
24.09.2017 05:49 <dir> mysql
24.09.2017 05:49 <dir> php
22.06.2016 14:18 1.730 uninstall-apache.bat
22.06.2016 14:18 1.695 uninstall-mysql.bat
24.09.2017 05:49 <dir> _logs
4 Datei(en), 7.551 Bytes
8 Verzeichnis(se), 142.767.554.560 Bytes frei
creating logs just in case
Ein Unterverzeichnis oder eine Datei mit dem Namen "C:\ProgramData\Themler" existiert bereits.
Ein
======== End of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log
ERROR:Unable to find file C:\Users\xyz\AppData\Local\Themler\Themler_vbs.log
======== Content of file C:\ProgramData\Themler\logs\startup.php.log ========
Sun, 24 Sep 2017 03:51:48 +0000
run from browser =
suffix = _1437116519
themlerDataPath = C:/ProgramData/Themler
icPath = C:/ProgramData/Themler/hd_data/themler_1437116519
url = http://127.0.0.1:12080/themler_1437116519
versionFile not exists
UnZip successful, target directory exists
Replace common.php result is 3930
======== End of file C:\ProgramData\Themler\logs\startup.php.log ========
======== Content of file C:\ProgramData\Themler\logs\apache\error.log ========
AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::c01c:14c0:3ee0:82ec. Set the 'ServerName' directive globally to suppress this message
[Sun Sep 24 05:54:18.111712 2017] [mpm_winnt:notice] [pid 3664:tid 1052] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Sun Sep 24 05:54:18.111712 2017] [mpm_winnt:notice] [pid 3664:tid 1052] AH00456: Server built: Jul 13 2015 10:37:15
[Sun Sep 24 05:54:18.111712 2017] [core:notice] [pid 3664:tid 1052] AH00094: Command line: 'C:\Program Files (x86)\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Sun Sep 24 05:54:18.111712 2017] [mpm_winnt:notice] [pid 3664:tid 1052] AH00418: Parent: Created child process 5320
[Sun Sep 24 05:54:18.896382 2017] [mpm_winnt:notice] [pid 5320:tid 1032] AH00354: Child: Starting 64 worker threads.
[Sun Sep 24 07:02:52.599432 2017] [mpm_winnt:notice] [pid 3664:tid 1052] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Sun Sep 24 07:02:54.623531 2017] [mpm_winnt:notice] [pid 5320:tid 1032] AH00364: Child: All worker threads have exited.
[Sun Sep 24 07:02:54.644971 2017] [mpm_winnt:notice] [pid 3664:tid 1052] AH00430: Parent: Child process 5320 exited successfully.
[Sun Sep 24 09:57:51.799602 2017] [mpm_winnt:notice] [pid 3876:tid 1052] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Sun Sep 24 09:57:51.799602 2017] [mpm_winnt:notice] [pid 3876:tid 1052] AH00456: Server built: Jul 13 2015 10:37:15
[Sun Sep 24 09:57:51.799602 2017] [core:notice] [pid 3876:tid 1052] AH00094: Command line: 'C:\Program Files (x86)\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Sun Sep 24 09:57:51.799602 2017] [mpm_winnt:notice] [pid 3876:tid 1052] AH00418: Parent: Created child process 4796
[Sun Sep 24 09:57:52.634740 2017] [mpm_winnt:notice] [pid 4796:tid 1028] AH00354: Child: Starting 64 worker threads.
======== End of file C:\ProgramData\Themler\logs\apache\error.log ========
======== Content of file C:\ProgramData\Themler\logs\apache\access.log ========
::1 - - [24/Sep/2017:05:56:29 +0200] "GET /themler_1437116519/startup HTTP/1.1" 301 258 0 mis
::1 - - [24/Sep/2017:05:56:29 +0200] "GET /themler_1437116519/startup/ HTTP/1.1" 200 30311 31251 mis
::1 - - [24/Sep/2017:06:01:31 +0200] "GET /themler_1437116519/startup HTTP/1.1" 301 258 0 mis
::1 - - [24/Sep/2017:06:01:31 +0200] "GET /themler_1437116519/startup/ HTTP/1.1" 200 30311 15628 mis
::1 - - [24/Sep/2017:12:10:24 +0200] "GET /themler_1437116519/startup HTTP/1.1" 301 258 1000 mis
::1 - - [24/Sep/2017:12:10:24 +0200] "GET /themler_1437116519/startup/ HTTP/1.1" 200 30311 30019 mis
======== End of file C:\ProgramData\Themler\logs\apache\access.log ========
ERROR:Unable to find file C:\ProgramData\Themler\logs\mysql\error.log
======== Content of file C:\Users\xyz\AppData\Local\Temp\themler_install.log ========
Starting onInit...
Calculating user folders for install...
Users folder for install calculated
onInit finished...
Starting main...
Copying main files...
Main files copied
Copying cms data...
CMS data copied
Copying rest of files...
Rest of files copied
Copying dumps...
Dumps copied
Main finished
Adding firewall rules...
Firewall rules added
Replacing config files...
Config files replaced
Installing MySql...
MySql installed
Installing apache service...
Apache service installed
Installing CMS content...
CMS content installed
Creating link and icons...
Icons and links created...
Opening control panel...
Control panel opened
Creating shorcut...
Shortcut created
======== End of file C:\Users\xyz\AppData\Local\Temp\themler_install.log ========
======== Content of file C:\ProgramData\Themler\hd_data\themler_1437116519\startup_logs\cms.log ========
Sun, 24 Sep 2017 03:51:51 +0000: openTheme(joomla)
Sun, 24 Sep 2017 03:51:51 +0000: install CMS
Sun, 24 Sep 2017 03:51:51 +0000: deployDB(joomla, joomla_, http://127.0.0.1:12080, /themler_1437116519)
Sun, 24 Sep 2017 03:51:53 +0000: MySql connection ERROR!
======== End of file C:\ProgramData\Themler\hd_data\themler_1437116519\startup_logs\cms.log ========
ERROR:Unable to find file C:\Users\xyz\AppData\Roaming..\Local\Themler\ChromeData\chrome_debug.log
