I am creating my own plugin for a custom post type called events, using the default WordPress installation in Themler Desktop Designer.
I need to manually load and edit files stored within the plugins directory, however I cannot do this because the WordPress directory itself is showing as a zip file. How can I work around this?
C:\ProgramData\Themler\cms_data\wordpress\wp-content\plugins
(The actual wordpress installation directory from the above file location is a zip folder)
Also if I upload and install my custom plugin to WordPress through the normal admin panel, the plugin will install but does not show when searching the plugins directory via the installation folders in Program Data
Hello, I am creating my own plugin for a custom post type called events, using the default WordPress installation in Themler Desktop Designer. I need to manually load and edit files stored within the plugins directory, however I cannot do this because the WordPress directory itself is showing as a zip file. How can I work around this? C:\ProgramData\Themler\cms_data\wordpress\wp-content\plugins (The actual wordpress installation directory from the above file location is a zip folder) Also if I upload and install my custom plugin to WordPress through the normal admin panel, the plugin will install but does not show when searching the plugins directory via the installation folders in Program Data
